happens to my car but mines jus 4ag n/a, if its same problem as mine check idle screw or ur throttle cable could be sticking somewhere like mine
ok. i just did a turbo conversion and all is good. after a few days of driving normally i took my mate for a spririted drive and when we came back the idle of the car was really high, i let it sit for a few hours then started it again and yea still idls high.
any suggestions as to whats causing it?
cheers.
ill check that as soon as some ones home to help me open the bonnet. but would it just happen all of a sudden like that? i held the throttle wheel thing down as far as it would go so i dont think its the throttle cabel sticking.
my car had same problem and could never figure it out, sent it to get tuned and the guy fixed it though the ecu, possible fuel mixture when idle?
im not sure champ like i got the same problem, today i had a long drive on like a 30 degree day, on idle goes up to 1500, then if i tap it up to 2 then it will idle on 600
Try some WD40 on the throttle linkage and the cam and give it a gut full of carbi cleaner, my mini and dato use to do that it's a pain , I think just with all the extra heat and metal expansion something mayb catching. Worth a try
have a look at all your hoses on your inlet vaccume or mayb inlet gasket is gone
