Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 31 to 40 of 54
Thread: best setup for hills
  1. #31
    Veteran Beau's Avatar
    Beau
    Dont forget the most import thing. Cup or water!
  • #32
    Senior Member ThatsHowWeRoll's Avatar
    Dean
    Ballina
    kaibeecee is a wise man....
    Set-up in the hills is different to drift....getting you chassis to work the best it can with the rubber is your goal....
    have a look at v8 supercars on the warm up laps and watch when they weave to heat the tyres....the amount of movement and roll will shock you.
    John 1:12
  • #33
    Quote Originally Posted by kaibeecee View Post
    going off this advice, i'd actually not take on board anything you wrote in either of those two posts
    common 86 drift setup = too hard rear springs, dampers too hard, tire pressure too hard. not going to be the most controllable car around consecutive corners, is it. which is a contradictory statement to your second post. and 'dip' into corners? what?
    do you mean that a bit of body roll to enhance tire grip or something. i hope you do.
    people tend to confuse tire grip with mechanical grip, and set their cars up so the two fight, and effectively counter each other.
    softer spring rates and stiffer swaybars does wonders as you're not relying totally on the tire, but assisting it to do its job at a safe rate
    you are fail!!!!!!!!!!!!! first i said TRACK not drift track. aka sprints and so on i also said not to different as in there are differences in areas but the general set up stearing and so on is changed yes softer for the hills and harder for the sliding you are verry smart . 2nd yes dip as in to increas grip aka slight body roll at a controlled rate.
  • #34
    Veteran Robo86's Avatar
    Rob
    lol man go easy on who you call "fail" around here.. Pete is a very knowledgeable guy.
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
  • #35
    Veteran driftke70's Avatar
    Ryan
    Buderim
    plus you cant have dip, and roll, cant really have dip in the first place,
    i rekon a good street set up, would be;
    6 and 4
    stiff sway bars
    good bushes all round
    rona arms
    agxs
    a fair bit of castor, not too much, around +3.5
    1mm toe out
    a ride height thats not stupidly low, so you can get some travel
    a 1.5 way
    matched tyres all round
    wheelfriends.wordpress.com
  • #36
    why so dip or roll what ever you want to call it is used by v8's, sprint cars and so on. just to clear up im not talking stupid amounts just enough that you can see it from outside.
  • #37
    Veteran Konakid's Avatar
    Henry
    Eastern
    dodge, dip, duck, roll and dodge
  • #38
    Veteran 45KIDS's Avatar
    Brodie
    Toowoomba
    went to a insane downhill today that me and a mate found. im liking my setup atm! cant wait to upgrade to better quality items
    atm just running:
    5 & 4.5kg springs
    kyb excel-G shocks
    rear 18mm swaybar
    front strutbrace
    panhard rod
    nice hugging fixed back seat.
    going to put some rona arms in and take it for another spin this week hopefully!
    plus re001's
  • #39
    Moderator
    Jay
    flag creek road?
  • #40
    Brodie
    Toowoomba
    ^^ nah man , went to flagstone creek road first. its nuts aswell haha. found one out in the middle of no where. who ever built the road had a phobia of straight roads aye.
  • Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    1. Replies: 2
      Last Post: 9th December 2012, 12:21 PM
    2. (SA) *E7*/86 BC/AJPS Rear Suspension setup/ 2871r turbo setup
      By sleeper_13 in forum Car Parts For Sale
      Last Post: 25th July 2012, 01:06 AM
    3. Replies: 11
      Last Post: 3rd October 2011, 04:58 PM
    4. SWAP W5 GBOX SETUP, FOR 4ag, FOR T50 SETUP!!
      By FAST EDDIE in forum Car Parts For Sale
      Last Post: 12th August 2009, 10:46 PM
    5. what to setup fuel pressure regulator at for 4agc setup
      By TRD_86 in forum Technical - Questions
      Last Post: 28th July 2008, 08:11 PM
