BEE R make a couple of different things , what thing do you have , im guessing the rev limiter?
i just bought a bee r and it come with intruction but i dont under stand japenise so i need the wiring diagram that has been converted into english would be a great help(im now going to test it in brendens 20v sprinter so would it be any different wiring into a micro tech computer with an x4 box???)
Rust is a way of life
yeh sorry bout that yeh its a rev limiter
a 1 second google search gives you this,
not english instructions but a fitting guide with pics
is there a wiring diagram or guide to tell you how to hook it to a microtech???
cheers man i did google it as well but i didnt find that one
hmmm i had one of these floating around when i had a bee-r
but it wont tell you how to hook it up to a micro tech, it showed standard smallport ecu and then straight off the dizzy
:lol:
[attachment=20433:nissan.jpg]
i know it's nissan but here's what i think
red: Ignition switched positive
Black: earth
grey and brown: loops are cylinder select so cut grey loop for 4 cyl
Yellow: goes to NE sig of your ecu wiring
Green: goes to G sig of you ecu wiring
White; goes to handbrake or a swich for launch control(rev2 limit)
the only thing you can do wrong is get the yellow and green wires the wrong way round, if you do this the car won't start, that's as easy as swapping the wires and it'll be all good
you'll need a 20V wiring diagram to find NE and G sig but someone should be able to help you
