Results 1 to 9 of 9
Thread: braking problems
    Senior Member kronix's Avatar
    Wade
    Stafford Heights
    Default braking problems
    i have a ke70 with t18 front brakes and a t series diff(out of a t18), all the brakes are new and disc's/drums have been machined, when i pull up hard the rear brakes lock up before the front brakes!!
    i was just wondering if anyone eles have had this problem and how do you fix it??
    Cheers Wade
    jarome
    vic
    traragon
    id possibly bleed the brakes
    Senior Member 4A-GE Power's Avatar
    Daniel
    Well if your braking hard there is a huge transfer of weight from the rear of the vehicle to the front hence making the rear light which would explain the rear brakes locking up so quickly
    Mt Macedon
    Still, despite weight transfer, the rears shouldn't lock before the front. Sure it can be fun in a rally car, but not the best for most driving.
    I'd check everything works, none of the calipers are seized, your proportioning valve isn't rooted and so on. The setup (T18 discs front and T18 drums rear with a stock KE70 proportioning valve) sounds like it should work fine.
    Wade
    Stafford Heights
    Quote Originally Posted by aussyboyz View Post
    the pedal isn't soft so there isnt any air in the brakes
    Quote Originally Posted by Hen may possibly be a nut View Post
    everything is working fine so i might try swaping the proportioning valve with another, i dont no if i should try a ke70 sedan one or a wagon one??
    CHeers Wade
    Veteran shift_rook's Avatar
    SE Burbs
    or can just get a wilwood one, like $80 from ebay, well worth it imo
    Mt Macedon
    Quote Originally Posted by kronix View Post
    ...everything is working fine...
    Or maybe not quite 100% fine.
    Have you checked it all out/rebuilt it? Or assume it's fine?
    Elite rthy's Avatar
    Leo
    Tulla
    maybe try using the t18 proportioning valve and brake master cylinder?
    Jonathan
    He should try a T18 valve. But the master cyl is the same. 13/16".
  1. Trail Braking.
    By motorculture in forum BENDIX Put your foot down with confidence.
    Last Post: 16th May 2012, 01:20 PM
  2. MOTO IQ article - Modeling Braking: Braking Harder Means Less Brake Fade
    Last Post: 14th May 2012, 04:28 PM
  3. braking
    By Tim.duncan in forum Grip and Tarmac Racing Section
    Last Post: 17th July 2010, 12:59 AM
  4. clunking under braking
    By seeknsqueek in forum Technical - Questions
    Last Post: 11th September 2007, 10:38 AM
  5. Engine stalling problems when braking
    By Joel-AE86 in forum Technical - Questions
    Last Post: 23rd November 2006, 11:47 AM
