Results 1 to 10 of 13
Thread: track suspension setup (everything)
    Josh
    Western australia
    Rockingham
    Default track suspension setup (everything)
    hey guys as title says im after a track setup for my ae71 but want to know wat frount end stuff to use like rca and power steering arms and stuff, kinda looking for the perfect drift package if there is one, as for the rear im unsure on it as its been so long since i played with rollas.
    thanks in advance
    josh
    Jonathan
    I think this is the generic shorthand answer your after. Easiest bolt together package anyway:
    Front:
    AE86 front stuts, shortened 40mm.
    2" ID 65mm spring coilover kit.
    65mm ID 200mm long springs. 7kg/mm or 8kg/mm rate
    TRD or Koni "short shocks" to suit JDM AE92.
    20mm spacer in bottom of strut tube.
    Cusco strut tops.
    Roll centre adjuster blocks.
    "Power steering" AE86 steering arms.
    "JDM" vented AE86 brakes
    Polyurathane bushes on control arms and swaybars.
    strut brace
    Or for more money (for the track):
    replace control and radius arms for ball jointed items
    use RX7 brake calipers and AJPS bracket, Honda disks.
    TRD blue adjustable shocks.
    Rear:
    Stiffer springs, maybe 4 or 5kg/mm
    shorter shocks. Adjustable. TRD blues.
    ball jointed panhard rod. Maybe Cusco.
    bolt on brackets between diff and lower arms (forgot the name).
    That is all.
    Josh
    Western australia
    Rockingham
    thanks for the quick reply johnny im intrested in a bit of explanation on above said bold bits photos or explanation is great and also is the coilover kit one of the ones ya weld on ect???:
    20mm spacer
    Site Supporter Javal's Avatar
    Josho
    Firstly, a suggestion:
    Use capital letters and correct punctuation when posting. It helps people understand what you're trying to say and makes look less like an idiot.
    Anyway -
    Step 1 - Remove wallet from pocket
    Step 2 - Open wide
    Step 3 - ???????
    Step 4 - Skids!
    Seriously though -
    Starting from the front working back - a true full package.
    Rose Jointed Castor rods
    Fatter swaybars (size of your choice) with new bushes - OR - Rose jointed swaybar links
    Rose Jointed length adjustable Lower Control Arms
    AE86 power steering arms
    Twin adjustable tierod tubes
    Quick Rack
    Roll Center Adjusters
    Height and Damper adjustable coilovers
    Camber tops / Camber & Caster tops
    Strut brace
    Rose jointed adjustable trailing arms -OR- Rose jointed equal length trailing arms -OR- IRS Conversion
    Uprated Rear springs + Adjustable shocks -OR- Height and damper adjustable coilovers
    Rose Jointed Adjustable Pangard rod
    Rear strut bar
    Rollcage.
    That's probably not even everything, but it's most of the suspension covered.
    Search next time.
    Josho
    Quote Originally Posted by meanmecordia View Post
    20mm spacer
    40mm is removed from the length of the strut so it:
    a) is closer to the correct length for the shock
    b) enables you to lower the car, and in combination with a RCA, keep your lower control arm angle correct and keep a decent amount of travel in your suspension.
    The 20mm spacer sits in the bottom of the strut tube to:
    a) make the strut length correct for the shock cartridge
    b) seat the shock cartridge in the strut correctly.
    Josh
    Western australia
    Rockingham
    thanks javal
    i was never good at english in school so my grammer is crap sorry mate will try clean it up a little next time.
    Josho
    thanks javal
    All good man, it just helps people understand what you're asking with more clarity.
    Dave
    i would suggest not going striaght from a completely stock ae71 to one of the above setups, because
    1 ) - it will cost you a absolute crapload up front
    2 ) - you wont learn anything
    my suggestion woud be: -
    1) get a full bush kit
    go and drive it
    2) get some decent sized wheels with good tyres
    drive it more
    3) get a set of coilovers for the front with camber tops (with the ae86 jap brakes)
    4) get some stiffer rear springs and shocks to suit
    5) panhard rod and RCA to keep it all in check
    6) new rack ends and tie rods will keep everything nice and tight
    7) a decent wheel alignment
    drive it alot more than the first 2 times and learn what the car is doin and the feedback that it gives
    now go and drive it more (you will have spent like 3k minimum so far)
    then you can fine tune with such items as roll bars, rose jointed items, traction brackets (i think thats what you mean johnny).
    i think braces are good to have as well, but dont go and buy 10 of them and put them all on. put them on one at a time and feel the difference of each one.
    car setup is a very individual thing to create, throwing money at a car wont make it handle perfect. you have to learn the car and design the cars suspension around the way you drive. what works for someone else prolly isnt gonna work for you (to the same extent)
    hope this helps anyway
    Josho
    Quote Originally Posted by ke70dave View Post
    allthatcrapbyke70dave
    Dave, i entirely agree with most of what you've said - going out and purchasing all that crap would be a terrible move for a beginner - however it is, as was asked - almost everything you'd want to have a 'complete' drift setup.
    For a starter drift suspension setup my recommendation would be, In order of purchasing -
    Pack 1:
    AE86 Struts w/brakes
    Short stroke shocks, f+r (KYB is a good cheap shock)
    8 + 6kg springs -OR- 6 + 4.5kg springs f+r
    Adjustable panhard rod
    Lock Spacer
    Strut brace
    14 x 7" zero-ish offset wheels (MA61's are a good choice)
    Other essentials-
    Locked borg warner (factory xe7x diff) or Locked S-series (factory ADM AE86 diff)
    Steering wheel and boss kit
    Seat, if you want
    This is a good starting point - plenty of people don't feel the need to fit any more components apart from a few select items from pack 2. Some other people do. It's a very well rounded package.
    Pack 2:
    Rebuilt Corona control arms
    Replace castor rod bushes
    Replace trailing arm bushes
    Camber tops
    Uprated swaybars f+r
    P/S arms
    Other essentials -
    T series rear diff + tailshaft to suit
    LSD to suit
    Just an building block on package 1. Offers more adjustment, more refinement, more steering lock. Set it up how you like it. Do skids.
    Pack 3:
    Start replacing all the gear from pack 1 and 2 with the big list of stuff from earlier.
    This is a good way to do it, i'm sure some others will have something to say, everyone does everything their own way - but that's my suggestion to you.
    Josh
    Western australia
    Rockingham
    all inputs are great guys, i have had a ae71 before that was track prepaired but not by me so as said its been a wile, but all is good as this thread could maybe be used in the tech section for other starters, or people looking for a diffrent type of setup to wat they have.
    thanks again guys
    josh
  1. Your Suspension Setup
    By sonsta in forum Technical - Articles
    Last Post: 30th April 2014, 01:39 PM
  2. (SA) *E7*/86 BC/AJPS Rear Suspension setup/ 2871r turbo setup
    By sleeper_13 in forum Car Parts For Sale
    Last Post: 25th July 2012, 01:06 AM
  3. Need Help With Suspension Setup
    By ArbPotatoes in forum Technical - Questions
    Last Post: 30th June 2009, 10:51 PM
  4. The Suspension Setup Thread
    By sr_rolla in forum Technical - Articles
    Last Post: 16th August 2008, 02:15 AM
  5. suspension setup
    By AE86_4life in forum Technical - Questions
    Last Post: 1st November 2006, 08:43 PM
