Results 1 to 4 of 4
Thread: t series info
    how i identify i no its has 10 holes for bolts on the center but wat else any info appreciated cheers rich
    Site Supporter Javal's Avatar
    Josho
    Id'ing them:
    Differentiating them from a borg-warner (KE70 / AE71 diff) and a S-series (ADM AE86, AE71 Panel van)
    easiest way to tell:
    Borg warner: Removable inspection plate (on the rear of the diff housing)
    S-Series: Removable 'nose' with 8 bolts holding it in (on the front of the diff housing)
    T-Series: Removable 'nose' with 10 bolts holding it in (on the front of the diff housing)
    If you're still skeptical, then you can pull out the 'nose' of the diff and measure the crownwheel sizes
    S-Series: 6.38"
    T-Series: 6.7"
    If you want to know what ratio it is, then this little bit will help (copied from old toymods)
    first digit: ring gear diameter
    A 138mm
    B 145mm
    C 6.25"
    D 6.62"
    E 7.1"
    F 7.5"
    G 8"
    H 9"
    J 9.25"
    K 9.5"
    L 10.5"
    M 12.5"
    N 13.5"
    P 14"
    Q 12"
    R 162mm
    S 6.38"
    T 6.7"
    U 6"
    V 10.6"
    W 15.5"
    X 142mm
    Y 158mm
    Z 202mm
    - no ring gear = FWD
    Second, third digits: gear ratio
    01 3.30
    02 3.36
    03 3.545
    04 3.556
    05 3.70
    06 3.889
    07 3.90
    08 4.111
    09 4.222
    10 4.375
    11 4.444
    12 4.625
    13 4.79
    14 4.875
    15 5.125
    16 5.286
    17 5.60
    18 5.714
    19 5.833
    20 6.167
    21 6.667
    22 6.78
    23 6.833
    24 7.64
    25 4.556
    26 5.571
    27 3.364
    28 4.30
    29 4.10
    30 3.727
    31 3.909
    32 6.591 or 4.807
    33 7.503 or 5.583
    34 6.781 or 4.786
    35 7.636 or 5.60
    36 4.778
    37 3.583
    38 3.417
    39 3.154
    40 5.375
    41 3.308
    42 6.500
    43 3.550
    44 3.214
    45 3.533
    46 2.928
    47 3.944
    48 3.356
    49 3.729
    50 3.400
    51 3.736
    52 3.722
    53 3.250
    54 3.941
    55 3.333
    56 2.821
    57 4.058
    58 3.238
    59 3.234
    60 3.519
    61 2.724
    62 2.892
    63 2.655
    64 4.312
    65 3.837
    66 3.071
    67 3.526
    68 3.095
    69 4.176
    70 5.857
    71 2.962
    72 3.949
    73 4.285
    Fourth digit: no of pinions, ltd slip-yes/no
    Code pinions ls
    2 2 no
    3 2 yes
    4 4 no
    5 4 yes
    This should be on the firewall of the donor vehicle, possibly on the diff (dunno)
    Width of the T Series housing from different models:
    TA22 (73 onwards), RA23, RA28 - 1365mm (mounts will not line up to xE7x / AE86)
    RA40, RA60 - 1410mm (mounts will not line up to xE7x / AE86)
    JDM AE86, TE72 - 1410mm (mounts WILL line up to xE7x / AE86)
    Those are the main ones at least.
    Oh, JDM Zenki T-series have the same axle thickness as ADM T-series diffs (TE72 ones)
    JDM Kouki T-Series have axles which are approx 1- 1.5mm thicker.
    Javal.
    Jonathan
    If it looks like a Toyota diff (not Borg Warner), and it looks unmodifyed, and it is a banjo style with 10 bolts, then it is probably a T series from a TE71/TE72/AE86. (AE95 also fits). If it looks unmodifyed but the control arms are maybe a little crooked, then its a T series from a TA22/RA23/RA40/RT132.
    thanks ppls ill find out wat it be and go from there
  1. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 08:12 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. F series info
    By ecko in forum Technical - Questions
    Last Post: 19th April 2011, 11:21 PM
  4. Info on F series diff ratios above 4.3
  5. Toyota A series info
    By damo46 in forum Toyotas in the Media
    Last Post: 20th May 2006, 11:00 PM
