baically you use adjustable cam gears to fine tune the cams.
you can adjust when the cams "come on" in relation to each other and crankshaft position.
they can be used them on stock cams aswell as aftermarket ones.
you have to be careful as to what cams to use in a forced induction application, too much duration will cause problems, as the boosted air goes straight out the exhaust cause the valves are open too long.
i am currently looking into getting some higher lift cams, to open the valve further. this should increase the amount of air going into the cylinder but with the same or similar duratuion time. ie the valve is open for the same length of time. it just opens further....if you can understand that
probably something round the 260 degree and 8.5mm lift
you will need to remember also that when upgrading cams its a good idea to get decent quality valve springs.....coil bind is very very ugly
