Results 1 to 10 of 10
Thread: A short history of Toyota variable valve timing
Threaded View
    Anthony
    Default A short history of Toyota variable valve timing
    Variable valve timing in Toyota engines.
    Early systems were open loop, and fairly conservative:
    VVT : Silvertop 4AGE (AE101 Corolla) - Single dimension (rpm only) switching of cam between no advance and full advance (about 30 degrees)
    VVTi : Blacktop 4AGE (AE111 Corolla) - i stands for intelligence. A couple of secondary dimensions added without much authority, namely engine temp and engine load (tps) as well as rpm of course. Still switched between no advance and a fixed amount of adv (30 degrees). Not much intelligence needed for these additions.
    More modern motors moved on to a closed loop system:
    VVT-i : 1ZZFE, JZX100 1JZ, JZS162 2JZ, Beams 3S and pretty much all new Toyota Engines - also called VVTi (confusing, probably caused a few arguments but the blacktop 20V was a fairly obscure motor on the world stage) - infinitely variable cam position on one to four cams by variable PWM oil control valve and/or phase controlled cam angle electric motor. Each VVT-i cam, in theory, can be put at any position between rest and full advance (up to 70 degrees on a beams inlet!) This actually requires an ecu with some intelligence.
    VVTL-i : 2ZZ-GE (ZZT231 Celica and ZZE123 Corolla, Lotus Exige) – L stands for lift. Apart from an oil pressure interlock (added to ensure swift engagement or none at all) it’s a simple open loop fixed rpm system between two different lift settings . The inlet cam timing section is still continuously variable however. It’s worth noting that when the extra lift is added the duration also increases. This makes this motor even more unique in the Toyota family.
    Honda: Honda have had simple open loop systems in their engines for many years. The big difference (and the reason why a civic will give an 86 a hard time) is that their systems usually change cam timing as well as duration at the same time. Only in their latest engines (K series etc) is the timing continuously variable (i-VTEC)
    You can learn a bit from observing how these systems work. For instance, on engines where both cams are variable, applying force to the inlet moves it to a more advanced position from rest, but applying force (duty cycle, PWM effort etc) to the exhaust cam, moves it to a more retarded position from rest. This can give clues as to performance cam settings versus low rpm, easy starting etc. Also worth noting is the range of the systems. 0-70 degrees adv for inlet cam, and 0-20 degrees retarded for the exhaust cam. This tells us which direction to start heading in and what sort of sensible ranges we can play with (on most systems anyway).
    The future: Anyone who has tuned oil pressure driven variable cams will tell you how fussy they can be. Different settings are usually needed for different rpm’s dues to oil pressure differences and other factors. Reaction time and consistency are big factors especially as emissions targets get more and more stringent. For this reason some new motors (like the 1UZ’s replacement, the 1UR-FE) have changed from an oil driven system to an electric motor on the inlet cam(s). This motor spins at close to engine speed with slight changes resulting in cam phase changes. This gives much tighter control. Once these electric motors improve their torque and reliability, it will probably mean the end of the timing chain/belt.
  1. 20 valve timing cover spacer (middle timing cover, alloy plate)
    By KE70Man in forum Cars or Parts Wanted
    Last Post: 26th August 2011, 06:30 PM
  2. Toyota TWINCAM history
    By 4.5AG in forum Technical - Articles
    Last Post: 28th January 2011, 09:37 AM
  3. advanced valve timing...
    By acidreign in forum Technical - Questions
    Last Post: 17th April 2008, 11:15 PM
  4. Replies: 5
    Last Post: 23rd September 2007, 11:04 PM
  5. Timing and valve clearances 3A-U
    By David in forum Technical - Questions
    Last Post: 12th July 2006, 09:26 PM
