Results 1 to 9 of 9
Thread: LSD final ratio changing.... can it, and how is it done
    Senior Member dave2221's Avatar
    Default LSD final ratio changing.... can it, and how is it done
    ooookay
    so here is my dilema, my hachi is a daily, and as such i drive down from syd to uni 4 times a week.
    if i was to get a 4.6 final on a 2way LSD that would put cruising speed 110km/h at about 4500rpm.....
    NOT PRACTICAL
    i want a LSD, but can i get one with a lower final, (around stock of 3.7) and then at the end of the year can i just change the final out for something more drift friendly? to something like a 4.3 - 4.5
    or do i have to change the whole centre, and get a new 2way with the right ratio?
    thanks
    Coolangatta
    You're only changing the crown and pinion, not the LSD (centre) but you will need to set it correctly otherwise the diff will whine and wear. I would recommend taking it to a diff shop to set up.
    You may be better off getting two carriers, and set one up with your LSD and fully sik drift ratio and another with a cheap open centre and more highway friendly gearing. If you've got a zenki rear end you could get a spare carrier off an old celica.
    Senior Member aaron's Avatar
    Aaron
    NOR
    ive got 2-way and 4.1 in my daily.
    i drive to uni four or so days a week (short run down the freeway)
    i think it pulls about 3400rpm at 100kph which is ok. i wouldnt mind going to 4.3 bit more fun on the street
    Veteran slydar's Avatar
    Dimitri
    http://users.tpg.com.au/users/loats/...gearboxes.html - ratios
    http://www.miata.net/garage/tirecalc.html - roll out
    check your maths. pretty sure youre a fair way out.
    remember stock adm is 3.9 (not 3.7), but thats irrelevant, stock jdm is 4.3. 4.6 is not a big jump.
    i run 4.8 and its no big deal. highway cruise is over 4k but not much.
    adm and jdm t50 have the same ratios.
    78's
    Dimitri
    also yeah, you just swap the raing and pinion, or, more likely, just take the lsd mech out of the lower (better ) ratio carrier and put it in the taller one.
    that way you dont have to set up the pinion again, which is the tricky part. changing the center can be done at home, you kinda need a rattle gun but apart from that you can do it by touch, dont really need the dial gauge/paint.
    78's
    john
    nsw
    liverpool
    Slydar, you might have saved me some cash .
    ok so i got a 2 centres . both zenki . one with a trd 2way with a broken 3.9 final ratio and the other from a celica with a welded +4.1 final ratio. so i can just take the 2way lsd centre out and re-install into the 4.1 without setting up the the pinion ??????
    Dimitri
    yeah, its fairly easy to set the back lash. just have a feel of the bearing tensions and back lash before you pull it apart, and then set it up the same.
    78's
    well in that case i might get a 2 way with a 4.5 final (or there abouts)
    and just use the stock final while i am going to uni.
    i got 30 mins each way on the freeway and with the current ratio it sits at 3300 or there abouts which means its pretty good on exhaust noise so its comfortable to drive.
    thanks for the advice.
    Member pandatureno86's Avatar
    Jim
    Nsw
    Kareela
    I have a 4.7
    does 80km @ 3,500 rpm
    the speedo is exactly 20km out.
  1. Gear Ratio (Final) Selection?
    By assassin10000 in forum Technical - Questions
    Last Post: 15th August 2011, 10:24 PM
  2. WTB LSD with 4.77 ratio T series
    By KKUSTOM in forum Cars or Parts Wanted
    Last Post: 19th December 2010, 01:18 PM
  3. Replies: 2
    Last Post: 3rd September 2009, 09:04 AM
  4. fs hilux final diff ratio
    By lewwy in forum Car Parts For Sale
    Last Post: 26th May 2008, 12:58 PM
  5. $450 shipped!!! 4.7 final gear ratio for T-series diff
    By thanhngo in forum Car Parts For Sale
    Last Post: 21st August 2007, 08:03 PM
