Page 1 of 87 1 2 3 4 5 6 7 8 9 10 11 51 ... LastLast
Results 1 to 10 of 863
Thread: Daims 20V 4AGTE KE70
    Senior Member Skid_KE70's Avatar
    Daimon
    Tasmania
    Launceston
    Cool Daims 310kw GT3076 20V 4AGE POWERED KE70
    Hey guys, just thought id throw some info and a couple of pics up on my corolla
    its been an ongoing project over the last few years, starting to come together now
    Specs:--------------------------------------------------------------------------------
    Front:
    PBM 8KG Competition Coilovers & Cambertops
    AJPS 40mm RCA
    AJPS fc brake upgrade kit inc slotted rotors
    AJPS extra lock spacer
    AJPS Bush kit,
    AJPS tie rod ends
    AJPS Braided Brake line Kit
    Mazda RX7 FC Brakes
    Redstuff Ceramic Brake pads
    Honda Civic Slotted & Vented Rotors
    No swaybar
    Just Jap Rosejointed Caster Rods
    Cut and shut NP steering knuckles (heyman copies)
    adjustable Noteched LCA's
    Rear:
    6KG PBM Competition Coilovers
    Madhouse Adjustable rosejointed Panhard Rod
    G Series Diff, 4.3 Gears
    R33 Skyline Twin Calipers & Rotors
    Hydro handbrake and willwood brake bias controller
    18mm Adjustable Whiteline swaybar
    Body:
    T18 Chrome Bars
    Self made Lower front lip
    Modified front guards to suit 7deg caster
    Fixed back Drivers Bucket Seat
    Sparco 4pt Harness
    Wheels:
    2x 15x9.5 -9 Work Equip 03 (Rear)
    4x 15x9 -3 Work Equip 03's (Rear)
    2x 15x8.5 -6 Work Equip 03's (Front)
    Engine:
    7 Rib Bottom End With Oil Squirters
    Fully Balanced Bottom End
    Spool Conrods
    ARP Head Studs
    ARP Main Studs
    ARP Rod Bolts
    ARP Flywheel bolts
    Silvertop 20v Head and Throttles
    Wiseco 8.5.1 Forged Pistons
    Supertech 1mm Oversized Valves
    Titanium Valve Retainers
    Supertech Valve Spring Kit
    TODA Adjustable Camgears
    Kelford Camshafts 8.5mm lift 272 Duration
    Garret GT3076R - .63 Rear
    Turbosmart 38mm Ultra Gate with screamer
    800cc Sard Side feed injectors
    10mm fuel lines to suit ethonol fuel & filters to suit E85
    Sard Fuel Pressure Reg
    2x Bosch 044 Fuel pumps
    2ltr Surge Tank
    Custom Rocker cover baffles with speedflow fittings
    20V Oil pump
    Trust Oil filter relocation
    Trust Oil Cooler thermostat and filter mount
    Cooling pro 25 row oil cooler
    Cooling Pro Intercooler 3" piping
    52mm 2 Core Alumium Radiator
    Davis Craig Electric water pump (Haltech Switches on at 70 deg)
    Haltech Sport1000 Ecu - Uses Magnetic crank pully trigger
    Self made high mount equal length turbo manifold
    Custom Built Intake Plenum
    Over 40 speedflow fittings used
    3" straight through exhaust in full stainless - no mufflers
    PERFORMANCE: 310KW @ 8000RPM and 810NM on 116 octane Martini Racing RE85
    Driveline:
    W5X Gearbox
    Nightparts Bellhousing to suit 230mm Flywheel
    Jim berry 4pk Unsprung race clutch
    Jim Berry 230mm Flywheel
    Custom machined rebuilt shifter
    Custom Solid Gearbox crossmember
    Old vid running 16v
    http://www.youtube.com/watch?v=5Z0T1nm8cg8
    New Vid - couple of laps at a practice day before i broke the inlet manifold
    http://www.youtube.com/watch?v=pVbS0CAjFOw
    Pics:
    With old engine
    New engine
    New Wheels
    More pics soon
    Let me know what you think guys
    Senior Member Sturgey's Avatar
    Jarrod
    Launceston
    looks great bro
    get some dx lights
    1984 ae71 Panelvan - Sold
    2000 Lexus IS200 - Cruiser
    性交を愛する
    HOLY FUCK.
    Glad to see you got some nice rims on it. Looks heaps better. Hot fucking stance.
    -rubs vag-
    Davey & Riki-lee
    South Australia
    Seaford SA
    great car dude so clean love it!
    got some engine bay pics?
    so much camber too! how much you running!?
    Senior Member addikt's Avatar
    Tyson
    pure sex bro love it
    Old username : hally
    Beige build in the works!!
    http://www.ae86drivingclub.com.au/fo...426#post874426
    Senior Member Dylan's Avatar
    Dylan
    front and rear fitment is ACE
    looks absolutely mint
    Senior Member Tally's Avatar
    Tally
    Quote Originally Posted by Dylan View Post
    X2 howd you get those bumpers to fit properly?
    I know you have flushed the panels to suit them but they fit on so straight!!!
    Engine bay looks insane!!! Whats it look like now?
    ALWAYS LOOKING FOR KE25 COROLLA PARTS
    Daimon
    Tasmania
    Launceston
    Cheers for comments guys, engine bay is a little plain atm because the engine is out, should be in in 2 weeks then il throw some more info up. We are modifying the water setup. Still have a lot of work to be done
    Veteran shift_rook's Avatar
    SE Burbs
    so damn nice. do want. i swear i just saw this in ignition volume 31??? it wasn't a feature car or anything, it was jsut some night meet and it had like 3 seconds of footage. omg famous haha
  1. Daims New Daily KE70
    By Skid_KE70 in forum KE70 / AE71 Owners Forums
    Last Post: 21st June 2009, 07:34 PM
  2. 35r 20v 4agte
    By 350hp4agte in forum Technical - Questions
    Last Post: 5th June 2009, 05:21 PM
  3. Daims Slantyface KE70
    Last Post: 5th February 2009, 06:55 PM
  4. Daims Slanty Face KE70
    By Daim in forum KE70 / AE71 Owners Forums
    Last Post: 13th May 2008, 01:23 AM
