R32 Non-ABS master cyl fits.
Hey guys,
I have to get myself a bigger bore master cyl for my brake upgrade.
The kit suggests a 1" master.
So my question is, Does anyone know of any larger Master cylinders that will bolt up to the AE86 booster?
I believe the Mitsubishi Starion Turbo one is a 1" and bolts up, but I have been looking for months, and are too hard to find. Brand new, and thru the Starion club, they are $415, and they said there was only one left in the country.
I have also heard something about an R32 or R33 (cant remember which one) one bolting up, but its not confirmed.
Does anyone know of any other Masters cyl's that might work for me?
thanks,
JoJo
1974 MX22 MARK II CORONA HARDTOP COUPE - Awaiting a full restoration
Hey man, srroy for not SMS'ing ya back, got busy with crap
"Tokico Brake Master Cylinder" is what i've got
it's a 17/16th MC with the same bolt pattern as the AE86/KE70
$270new
Pic
i bought a r32 with abs MC from nisswreck for $100 bolts straight in and needs orignal lines to be modified to suit
See if you can find a partnumber for that. Not that it's toyota, but it will be something.
Correct.
I'll try and find one, but from memory, it didn't have one in it.
What size bore is then Mitsu Paj one?
And What size is the Nissan R32?
Mitsubishi Pajero one is 15/16 bolt straight on Aus 86 booster. But one of the outlet use a different fitting. What brake setup are you running that require a 1"?
