5 g's now farkin hell! way to cheap dude, love it to death, simplicity has never turned me on so much
For sale: 1985 ADM Ae86
Asking Price: $5000 firm
Killometer's: 230*** on chasis, bit over 100*** on engine.
Manual or Automatic transmission: 5sp Manual t50
Engine Type: JDM 4age 16v (no oil leaks)
Condition: Bit of rust here and there, in the middle of repairing one bit its in primer at the moment, Dents on drivers side rear, hard to see, previous owner did those...
Modifications:
Cusco front strut brace
25mm spacers on front
30mm spacers on rear with rolled gaurds to fit
Shaved keyholes on passenger side door and hatch.
Deep Dished steering wheel
Boss kit
Bucket Seat
AJPS Coilovers up front with adjustable kyb agx shock absorbers in the rear (They all knock for some reason, im guessing incorrect installation as they were brand new when previous owner put them in)
T3 panhard rod
8kg front springs
6kg rear springs
T3 camber tops
T3 camber top hats
Konig Rewing rims charcoal with chrome lip 15 x 7
Toyo Proxies 195/50/15
JDM 4age 16v engine
JDM efi fuel tank
K&N washable cone filter with enclosure
JDM ECU
JDM Exhaust Manifold
Cat-back Exhaust with twin 3" pipes (under the diff)
Rebuilt t50 gearbox which was done at CATS 3 years ago. (Tight gear box with smooth changes both up and down gears no nicks)
230,000 on chasis
New radiator
New Spark plus leads
Recently changed oil
Brand new pioneer head unit and 6" and 6x9" speakers
New Master Cylinder and clutch hose
Dash and dash surrounding sprayed flat black
Rego till June
All electrics working.
Registration: 28th of June i think
Crash History: Bit of a dint under the rhs tail light, someone decided they didnt like me and smashed the glass out of my drivers side mirror, bent the lhs mirror backwards so the inside mechanism snapped but the mirror is still in place, anddd they kicked a peice out of my rhs tail light...all shown in the photos. Plus i rolled the gaurds to fit the spacers on the wheels and they look a bit ghetto, needs some bog and a spray
Other Comment's about the vehicle: Drives fine i love it but the gf isnt a fan so im updating to a 180. Also one of the spark plug leads is loose, easy and cheap fix if you can get your hands on one
Contact: Rhys. I prefer SMS on 0449221675 but if you have to call then ok..or just PM here im on here often
Pics:
mmmm i know it is pretty sad haha but im moving on and need it gone
sweet ride man i would defently buy it if you were in vic. Not comein to vic any time soon
^^ +1....come down to vicc!
hey man does this have back seats also does it run fine the way the spark plug lead is? What do ya recon it needs for a roady?
pm'd aussyboyz
but for the record. it runs fine how the lead is, just doesnt sit on the plug properly but its been like that for months now and hasnt played up
for roady..
i reckon the gaurds would need to be cleaned up (bogged etc)
get the bucket welded properly beacause im not exactly the cleanest welder but it is strong..
new bulb for the tail light but i will most likely do that
maybe glass in the drivers side mirror??
but apart from that i think its pretty sweet
also one thing aestheticaly i forgot about..
when i put the speakers in i put the drivers one in where the window hit it where it wound down so there is an extra hole in the door card..
soldddddd 5k
