Results 1 to 8 of 8
Thread: AJPS 8kgmm 210mm free hight front springs, What shocks?
    Member ONCE-NA's Avatar
    Rod
    Ballarat
    Default AJPS 8kgmm 210mm free hight front springs, What shocks?
    Hey guys, I have some AJPS 8kgmm 210mm free hight front springs, What shocks would suit. ei. what part number of from what car would suit in terms of being short enough to keep the springs captive and preferably suitably valved to suit the springs. Its for a AE86 with standard struts.
    Rod
    Ballarat
    The ST185?
    In my 22 I'm running SW20 Rears in the front, cant remember what length they were though
    Senior Member adam's Avatar
    Adam
    Yep, ST185s. The Celica shocks are slightly shorter than the MR2s.
    More in this thread.
    http://ae86drivingclub.com.au/forums...ead.php?t=1115
    Rod
    Ballarat
    Cool thanks guys
    Aaron
    with my 210 8kg springs im running kyb agx that i got from ajps with the t3 spacer.
    prior to the t3 spacer i was running a spacer below the shock, but it didn't feel right. not only that the spring was far from captive.
    now with the t3 spacer sits better, feels better and the spring is still uncaptive but not far off being captive
    zilla
    nsw
    central coast
    I have the same front springs, 8kg/mm x 210 free height, from AJPS.
    I use HTS102 dampers with a spacer beneath them, in a full length strut (ie uncut). The spring is not quite captive, but almost. My rubber spring seats have deteriorated, but with them I dare say it would be captive.
    However, the HTS has a stroke approx 25mm shorter than your celica items, so as others have said, I doubt yours will be close to captive with 210mm springs
    Moderator Sam-Q's Avatar
    Endeavour Hills
    what dont you like about the T3 spacers Dave?
    Skit: I think in real world use its not the free height that determines if the spring will be captive or not, its the shock extended lenth and the ride height. I am using 180mm 4.9kg free height springs and they are captive.
    Jonathan
    8kg is fairly stiff. I think it would go beyond the capability of any regular non-adjustable shock. So you need a good quality shock, with adjustment.
    As for fitment, any of the short shocks talked about. ST185, ST162, SW20 rears, AE92 Japan or USA version etc. Maybe use a 30mm spacer at the bottom, and a 30mm spacer at the top.
  1. Replies: 1
    Last Post: 3rd April 2011, 09:01 AM
  2. front springs 210mm/6kg for my ke70
    By Jacobxxx in forum Cars or Parts Wanted
    Last Post: 24th April 2010, 10:37 AM
  3. 8kgmm front, 6 kgmm rear springs too stiff for shocks
    By ONCE-NA in forum Technical - Questions
    Last Post: 13th February 2010, 05:01 PM
  4. Replies: 1
    Last Post: 30th December 2009, 02:17 PM
  5. SOLD AJPS 8KG - 210mm Springs
    By marvis in forum Car Parts For Sale
    Last Post: 21st June 2008, 12:40 PM
