Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 31
Thread: Cheapest ITB Trumpets Available
    Default Cheapest ITB Trumpets Available
    As above, looking for 20v BT ITB stacks & money is tight, + it kills me to buy all this shit again.
    These dont come up 2nd hand.
    Been looking at T3 & the nice secection that Jubiride have available but the cost a small fortune landed.
    I suppose the real answer as to whats the cheapest would be the original plastic ones that come in the standard airbox
    Mark
    http://cgi.ebay.com/ebaymotors/VW-WE...1%7C240%3A1318
    Not sure whether it was these exact ones, but i bought a full set which cost something like $70 AUD delivered on american ebay. Was a buy it now price as well!
    Senior Member 4.5AG's Avatar
    Vener
    NT
    Lyons
    cheapest I have come across so far..Do you have the dimensions..what is the top and bottom internal diameter,
    Is it a direct bolt in to silvertop quads? or needs modifying.
    Veteran slydar's Avatar
    Dimitri
    u will need to slot the holes.
    the cheapest way to do it is make your own from frp.
    ive done it, its pretty easy.
    i used a bit of pvc pipe, heat the end on the stove and flared it out. cut the base plate off the stock one, put the tube with the flared end on it in that, bam, 2 piece plug.
    performance wise, they wouldnt be really amazing, but they cost fuck all and look cool.
    78's
    Quote Originally Posted by slydar View Post
    Mint any pics?
    The actual port is a different shape, if that answers the question mate.
    Mark
    yeah if those are the same ones i got, you have to slot the holes a heap. and the trumpets are a smaller inner diameter than the throttle bodies by about 2mm. really doesn't seem to make much of a difference though, certainly not $150 worth of difference. Sometimes i wish mine were a bit prettier but then i realised that if i had pretty ones they would still be covered by the ugly filters
    Dimitri
    Quote Originally Posted by floody View Post
    How great is the difference between DCOE pattern and 20v throttles? will slotting them to suit only work for blacktops or silvertop too?
    st is 45 at the opening, 43 at the butterfly.
    bt is 48 at the opening, 45 at the butterfly.
    so, really i would only run stacks meant for 45mm dcoe's on st's. i think you actually have to cut it so its an open slot, not a elongated hole.
    ive had a few hachis now.. lol.
    78's
    wouldn't PVC melt at that temperature??
    Dimitri
    the stacks are made of fiber glass. you use pvc for the plug. and either way, no, it wouldnt melt i doubt, especially with the intake air being sucked through it.
    those stacks lasted at least 5 years and are still in one piece. gilly bought that engine off like the 3rd owner of the car since i had it.
    ive heard of people even using pvc pipe for not so temporary IC piping.
    78's
  1. NSW - silvertop ITB trumpets
    By meadan in forum Car Parts For Sale
    Last Post: 6th March 2011, 04:04 PM
  2. ITB trumpets for 20v and set of springs (ae86)
    By Motormotion in forum Cars or Parts Wanted
    Last Post: 24th February 2010, 07:42 AM
  3. Question about ITB trumpets
    By Rice86 in forum Technical - Questions
    Last Post: 16th February 2010, 04:49 PM
  4. Replies: 11
    Last Post: 15th January 2010, 02:58 PM
  5. WTB: Cams Gears, ITB Adaptor, Trumpets, Mounts
    By haydenzz in forum Cars or Parts Wanted
    Last Post: 14th April 2008, 10:25 PM
