Results 1 to 4 of 4
Thread: injectors/coil packs
    dan
    adelaide
    adelaide
    Default injectors/coil packs
    hi im going to be putting my quad throttle set up on soon
    its going onto a big port 4age
    just to be on the safe side what are some direct plug in injectors i can use?
    ive heard the 7mge ones fit or the 4agze
    also what coil packs should i use or what car to get them from?
    i will be using a microtech lt10
    any help would be great
    Veteran Nikkojoe's Avatar
    Tom
    Injectors on bigports are square plugs, same plug are found on 7mge. The rest are smallport styled injectors (round plug, not square) - 4agze are round plug. The 7mge injectors would probably be best for your use.
    dan
    adelaide
    adelaide
    part one fixed
    now onto coil packs or coil on plug set up
  • #4
    Jonathan
    There is lots of space between the cams on a 4A-GE, so you can use any coil-on-plug you like, and the brackets will be custom that you make.
  • Similar Threads
    1. coil packs
      By race4ages in forum Car Parts For Sale
      Last Post: 10th August 2012, 08:58 AM
    2. Coil packs
      By LEVIN86 in forum Technical - Questions
      Last Post: 30th September 2011, 09:33 PM
    3. how many coil packs do i have ?
      By #109 in forum Technical - Questions
      Last Post: 15th June 2008, 03:52 PM
    4. coil packs
      By stuartgze in forum Cars or Parts Wanted
      Last Post: 26th October 2007, 07:08 PM
