Results 1 to 5 of 5
Thread: How To: ae71 centre swap
    Default How To: ae71 centre swap
    Hey Guys,
    New to ae86, If someone can give me a run down of how to change centres or do it for money or a slab or something.
    Thanks Borey
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Swapping a centre in a borgy is a fairly big deal, better off just swapping housings with the centres still in them. If you do swap the centre you really should get it done by a diff shop so that its all setup correctly.
    An AE86 diff is much more simple and can be done at home.
    Senior Member adam's Avatar
    Adam
    It's a bitch of a job, but here's how you go about doing it.
    Jack car up, place on stands.
    Undo shocks.
    Take wheels off.
    Loosen hand breaks then take drums off.
    Get a 15mm socket and undo the 4 bolts holding the axles in on each side.
    Take axles out (probably the hardest part), use a slide hammer or just put drum back on backwards, screw in two nuts lightly, use the drum as a slide hammer.
    Undo the diff plate, 13mm from memory. Don't forget to place a bucket of some sort under to catch oil.
    Undo brackets which hold centre in by using a 16mm socket, should be four, two each side.
    Pull diff centre out.
    Go back for installation.
    I might've forgotten a step..
  • #4
    Cheers guys,
    When taken the axles out, is there a c clip to hold them in place. Or do i just have to pull them out and thats that!
  • #5
    dont forget the shims in the diff!!! make sure when you take the diff out. there will be 2 little oil seal looking things on either side in between the diff houseing and the bearings. these have to go back in in the exact same place otherwise the diff will be stupidly noisey. trust me. i put up with it on a daily basis.
  • Similar Threads
    1. NSW: FS/SWAP TRD 2way ZENKI centre t-series
      By tezza88 in forum Car Parts For Sale
      Last Post: 16th April 2011, 10:17 AM
    2. ke70/ae71 diff centre
      By chin70 in forum Cars or Parts Wanted
      Last Post: 30th June 2010, 09:59 AM
    3. WTB: T series open centre. Or swap for locker.
      By svenmate in forum Cars or Parts Wanted
      Last Post: 14th January 2010, 07:30 PM
    4. WTD: Ae71/Ke70 centre bearing or tailshaft
      By hugh in forum Cars or Parts Wanted
      Last Post: 6th December 2009, 01:21 PM
    5. Replies: 10
      Last Post: 9th July 2009, 11:31 PM
