Results 1 to 3 of 3
Thread: 4ac Cam oil seal
    Tigh
    Vic
    Southside
    Default 4ac Cam oil seal
    Fired up the old 4ac today & there's a huge oil leak from the camshaft.
    Question is, what diameter is the seal & do 4age Cam seals fit as i have a few of them lying around.
    CHeers
    Veteran Nikkojoe's Avatar
    Tom
    You are better off just buying a new one, wouldn't cost a lot.
    Jonathan
    The oil seal is not the same as 16v 4A-GE. But it is the same as 4E-FE and 4A-FE and 3S-GE and 20valve. They have lots at the shop, cheap.
  • Similar Threads
    1. Replies: 3
      Last Post: 21st December 2011, 05:46 PM
    2. Replacing front main oil seal (crank oil seal) 4ac.
      By dreny... in forum Technical - Questions
      Last Post: 18th June 2009, 03:21 PM
    3. T50 rear oil seal
      By Tom86 in forum Technical - Questions
      Last Post: 17th March 2008, 12:28 AM
    4. how to take out rear main oil seal retainer
      By driftster in forum Technical - Questions
      Last Post: 2nd July 2007, 02:48 AM
    5. 4age rear main oil seal
      Last Post: 27th June 2007, 02:34 PM
