no one wants hachi parts????
ae86 bobtail fibreglass black in color no damage $100
ae86 drivers door adm side mirror white $30 SOLD PP
ae 86 drivers side door glass good condition $ 30
ae86 drivers side door triangle window thingy $ 15
ae 86 drivers side door trim (arm rest, book holder thingy, window winder plus fabric trim with hole cut out for speaker bottom left corner blue in color $20 or will separate $5 a piece
ae 86 drivers adm door minus tirm and everything jus door with medium dint in lower left corner maroon in color $25
ae86 front windscreen side trims gloss black good condition SOLD PP
4age injector rubber stoppers unused still in bag $10
ae86 mud flaps with bonus mud $10 set
dizzy o ring $4 SOLD PP
random 4age copper washers unused $2
ae86 heater hose $5
r32 non abs brake master clyinder $60 SOLD PP
straight fit in 86 jus need to move lines to suit
ae86 spark plug leads holds from dizzy 8mm width per holder $5 SOLD PP
random 4age gaskets brand new $2 each
4age bigport throttle body gasket brand new $5
4age exhaust flange gasket brand new $5
4age cam shaft oil seals intake and exhaust brand new $10
J racing strut top bolts brand new unused $10
water washer bootle bracket $2
ae86 strut tops gc $50 for both $30 each
ae86 bulbs ok for replacing a blown not much else $5 for the pair
coilover nuts the one that sits on the thread QTY 2 $15
graphic equiliser 16 $15
sick of having presets make your own full 80s style goes well with 86 standard tape deck and radio
ae86 boot light $5
4age bigport valley rubber seal $5
4AC alternator $15
unsure condition
ae86 drivers seat $35
good condition no holes or rips little bit dirty good for rwc
20 v radiator + 12" thermo fan $30 will separate $20 for radiator and $20 for fan
ae86 floor carpets brown in color front and rear hole on fronts front $10 rear(no holes) $15
federal super steel 535 195 x 50 x 15 $30 each
camber worn in the first inch of tread (no road legal) rest of tread is near new
4ac volt regulator $10
unsure condition
JDM rwd water pump $20 SOLD PP
used worked fine when on car
swoosh oil temp guage $60
68mm 40 -150 C with temp sensor electric...still in box unused
toyota thermo fan $25
diameter 12.1 " depth 3" off 20v radiator
ae86 air con face plate $15
no cracks good conditino
4age bigport spark plug leads $60
8mm no damage worked well replaced for 12mm leads
AC selector switch (2 for sale) good condition $10
SAAS air filter used $10
bit dirty could be washed small dint in lower side
AE86 standard radio and tape $15 XX SOLD XX
all the shit for your 80s style and better then 8 track good condition worked before removed
Ae86 aircon cable for selector $2
heat and cool lines
ae86 tailshaft $100 bigger half $60 smaller half $45
220,000 kms when removed
only 4ac power good condition no accident damage
headlight switch (not plastic cover) for ADM 86 not sure if it will work in JDM will try on mon coming and update if it works $70
ADM 86 drivers side parker has been broken on the outer clear plasctic cover inside unbroken still works $15
ADM 86 side exterior trim drivers door and drivers rear qtr black in color good condition jus asking what i paid $20
2 x mirrors with glass good condition black in color $30 each
1 x mirror without glass good condition black in color $25 each
1 x adm passenger side headlight good condition $75
2 x complete (well think so have not yet checked) interior trim one is black in color has been professional had moulded carpets attached to all trim throught out
carpetted trim good condition
black trim near new condition
NO DASHES but center consoles and cluster surrounds and air con vents available
1 x pair KONI RED rear shocks short strokes still very firm good condition $150 for pair
1 x black rear seat top and bottom half good condition $50
1x inline fuel pump (fuel pro brand) 12v (can give all pemp specs on request)
bought it on saturday 2nd of feb jus gone to try and get car running.....didnt work (not pump issue) pump used for maybe 20mins max
have reciept for purchase from repco paid around $120 think( will drop sale price if i paid less) for sale @ $95
1 x std AE86 ADM radiator few fins bent not sure if it works average condition $25
1(EIO) x JDM toyota floor mats circa 1985 with "LEVIN" printed in large letters on top grey/blue in color vgc
make an offer
1x whiteline dash good condition no crack $220
all pending payments will be held for 14 days and returned for sale unless deposit is recieved
all parts can be post at buyers expense small things such as gaskets can be mailed for free
pics are available on request and all prices are neg...
more parts will be added soon cheers
Hey mate would you consider swapping your front windscreen side trims for a s- series diff centre, if not how about some money.
side trims are sold PP ur third in line and no don't want an s series center thanks
ae86 seat belts front both sides $25 pair $15 each
If the exhaust flange gasket is for between the block and the extractors, il take it posted to Lismore, NSW 2480 for $10.
pics of the 20v radiator?
put 10 in bank account if they don't fit send them back and ill give you the 10 back
details
mr richard sedlbauer
bsb 734 640
account number 552703
and pics of the 20 v radiator will be uploaded tonight cheers rich
Where abouts in brisbane are you? wouldn't mind coming by and having a look at all the peices.
