Results 1 to 6 of 6
Thread: front shocks
    Senior Member DRFTR86's Avatar
    Richard
    South Oakleigh
    just want to know will my kyb excel g inserts i have at the moment be ok to use with a t3 weld on front coilover kit with a 8kg eibach spring
    advice???
    Thanks, Rich
    my bad oni-70
    PROTEK TYRE AND AUTO
    SQ ENGINEERING
    NCCE
    Veteran Beau's Avatar
    Beau
    in english? You know i don't speak spanish!
    Senior Member amulday's Avatar
    Amulday
    Central
    If you are using 86' struts it should be fine, you just need a spacer unless you plan to shorten the strut.
    amulday.sam
    HR ARMY
    RED BEAR
    Richard
    South Oakleigh
    y shouldnt i try to weld it on????? as in myself not weld it cos i wont be
    SQ ENGINEERING
    NCCE
    Jonathan
    From what I know, the excel g shocks are fairly normal replacement shocks? Not really a stiff adjustable shock. So maybe the 8kg springs would be a bit too stiff for them. Sure it will work, the car just won't handle the best. About 6kg/mm front springs are the limit for many replacement shocks for good handling.
    Veteran Konakid's Avatar
    Henry
    Eastern
    <div class='quotetop'>QUOTE (4agteketo @ Feb 7 2008, 01:58 PM) </div>+1, isnt it alloy? Buy a proper steel coilover kit.
    The excel g is a standard replacement shock yes, but being from a heavier corolla it has stiffer valving. I have found it to be surprisingly good at keeping up with 8kg front springs although it could be slightly stiffer, more so on rebound.
  1. Front shocks.
    By Ksevn-T in forum Technical - Questions
    Last Post: 6th March 2009, 01:11 AM
  2. cheap front shocks
    Last Post: 8th February 2009, 12:29 AM
  3. Front shocks
    By egg_83 in forum Cars or Parts Wanted
    Last Post: 7th February 2009, 08:01 PM
  4. Front Bumper and shocks
    By Mudkip in forum Cars or Parts Wanted
    Last Post: 24th January 2009, 12:21 PM
  5. Front shocks
    By kiwi in forum Technical - Questions
    Last Post: 24th September 2007, 01:07 PM
