Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: wiring trueno headlight motors
    Senior Member EVOSTi's Avatar
    Kevin
    Camden
    Default wiring trueno headlight motors
    done a bit of searching on google, havent come up with anything.
    i realise this is probably very simple, but was just wondering what the deal is with wiring the trueno headlight motors? is it a case of running a relay from the headlight power feed leaving constant power to the motor while the lights are on? or is there a signal wire to wind them up or down? i assume the later is the case.
    i hear celica motors are the same (st184?), are the plugs the same? i would rather cut a plug off a celica to attatch the the trueno motor than cut the plug of the trueno motor and run straight to the relay.
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    bump on this
    i recently cut a ra60 headlight wiring loom out of a ra60 and attempted to put that in. it only had 1 relay. everything wired up and the headlights keep going up and down....
    do i need another relay? i think i may have cut the loom too short and missed a relay.
    are there any easier options? does anyone know of a loom apart from a genuine trueno loom that is more plug and play?
    Kevin
    Camden
    so the plugs for the motor are the same?
    i had an ST185 GT4 come into work a while ago and the plugs were different.
    i put my front end on the other week, just pluged the lights in and re wired the blinker plugs but not the motors. theres a guy with a trueno converted sprinter near me who comes into my work some times, and he had his motors wired up by an electrician. he runs one relay for each motor. ill hunt him down and check it out.
    Scott
    Gympie
    Hey guys, none of the plugs are the same, the only Toyota with the same relays to send em up is the MA60 and RA60, when i did mine, we adapted a st185 headlight control box as it did away with a relay, standard set up uses 2 individual relays, one in the cab, one in the engine bay, this way i've only got the one in the cab, as for wiring, your best bet is to look in the AE86 wiring diagram, its what i had to do, and just fuck around with em. you'll figure it out! good luck!
    Dan/Rio
    Randwick
    i might end up paying an auto electrician if i cant work it out myself. would be $300 max.
    yeah ra60 gear hooked up fine but i thought i was missing a relay. when i go back to the wreckers tomorrow ill check out inside the dash or the ra60 i ripped it out of aswell as check out the st1xx celicas and see if i could adapt one of those looms
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Yeah as said, I'd probably go with SA63, RA65 or MA61 wiring for the lights. They use the same control relay as a Trueno.
    If you still have your Trueno front end and I still do your engine wiring for you I can probably nut it out do the headlights too.
    Scott
    Gympie
    the RA60 will have at least 2 relays in it. theres a little blue box under the dash, and some black ones in the engine bay. u havea few left over wires when u do the st1xx way lol, but trial and error sorts it out.. lol,
    u need 85963
    and 85964
    one u have those, your set, try and get a bit of loom with them aswell, so u can just make the wires join up, mash them with your current loom, and make magic, have a go your self, its good fun
    Dan/Rio
    Randwick
    ive got 85964 (the one in the bay) and should pick up 85963 tomorrow. if i fail ill try a st16x loom and if i fail at that ill pay golberg when he comes to redo my engine.
    golberg you have pm about my engine
    Scott
    Gympie
    Quote Originally Posted by Golberg View Post
    Yeah as said, I'd probably go with SA63, RA65 or MA61 wiring for the lights. They use the same motors as a Trueno.
    Pretty sure the motors are different dude, they all have different part numbers, the only things that share part numbers are the relays.
    Lawrence
    Wollongong
    Just been looking at it, yes there are 2 relays, one inside the cabin, one outside.
    I can't see why I wouldn't be able to hook it up for anybody, If anybody wants it done PM me, but you'll have to get in line.
  1. Headlight wiring issue
    By barnzy - ksev in forum Technical - Questions
    Last Post: 5th May 2010, 09:34 PM
  2. trueno pop up lights including relays and motors + REAR BAR
    By julzy in forum Cars or Parts Wanted
    Last Post: 29th March 2010, 05:40 PM
  3. For Sale RX-7 Headlight Motors
    By Lewis in forum Car Parts For Sale
    Last Post: 8th March 2008, 02:24 PM
  4. Wiring EA falcon headlight switch
    By drew86 in forum Technical - Questions
    Last Post: 11th June 2007, 02:38 AM
  5. trueno headlight motor relay wiring
    By sanchez in forum Technical - Questions
    Last Post: 29th September 2006, 12:23 PM
