Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: rx7 FC, which skyline master cyl to use?
    Senior Member dave2221's Avatar
    Default rx7 FC, which skyline master cyl to use?
    Hi Guys.
    doing a rx7 brake upgrade, called my friendly nissan dealership to order a new brake master cyl.
    i have been told there are a heap of them to chose from depending on engine model (turbo or non-turbo), and 2 differnt fitting sizes available for a rb20de r32 skyline (non turbo)
    anyone know whether its the 15/16 size fitting or the 1 inch fitting?
    or does anyone just know a model number, or a VIN number for a skyline that i can use?
    help is appreciated.
    Scammer, DO NOT BUY FROM ME!
    the non abs variety in the r32 kind
    HAHAH I LOVE BOOST LOOSING!!
    gay
    n1gger land
    n1gger land
    south korea seoul
    has to be a non ABS MC.
    edit... looks like sonsta just beat me to it as i typed.
    yes, but hte parts department at nissan need a part number.
    i know what type i need, but i need to tell them how to find it.
    their parts system doesnt differentiate between abs and non-abs
    性交を愛する
    You will be looking at around $400+.
    You are after a BM44, which the parts numbers are #46010-05U01 (Tokico) or #46010-05U21 (Nabco)
    marvis.
    thanks. i also found it online.
    the tokico is the one to go with, as the nabco is discontinued.
    Price is actually closer to $500
    Member Jase86's Avatar
    Jason
    Melb. S.E.
    You can use the ABS variant - it just has two ports like the AE86 master so you run it into the old splitter.
    "go forth young man, and if it has more..... pull fifth"
    Senior Member Simon-KE70's Avatar
    Simon
    yes but if your going to do it properly, you should ditch the old splitter and use a NON abs master which has a proportioning valve built in.
    I use a R33 item which has 3 ports (2 F and 1 R) the rear has a proportioning valve built into the MC.
    i wouldnt waste your time buying a new one... they can be had for around 80 in good cond.
    Jason
    Melb. S.E.
    Fair enough. I'm using the ABS master, removing the guts of the OEM splitter and putting an adjustable bias on the rear line to tune front/rear bias. Just another option but probably more stuffing around if your just after a simple solution.
    Quote Originally Posted by Simon-KE70 View Post
    where can you get them from?
  1. Boosterless Twin Master Cyl Brake Setup
    By PRIMRK in forum Technical - Questions
    Last Post: 11th March 2011, 10:41 PM
  2. Replies: 9
    Last Post: 28th October 2009, 02:41 AM
  3. speedo cable, brake mater cyl, clutch master cyl
    By dr1ft-pig in forum Car Parts For Sale
    Last Post: 9th June 2008, 12:24 PM
  4. Toyota 15/16 Master cyl
    By Jonny Rochester in forum Technical - Questions
    Last Post: 27th December 2006, 11:40 PM
