Page 1 of 8 1 2 3 4 5 6 7 8 LastLast
Results 1 to 10 of 77
Thread: what 4A for drift?
    Timmy D
    North
    Default what 4A for drift?
    I was at the DA round last may at la la and the comentator said somthing intresting "drifting is really hard on your motor" ......."um der Tim".... Hear me out. The fact that your car will sit there at the start line, then sit on the limiter for half a track and get up to high temps, Taxi for half a track then sit there again where it will cool back down. you stay stationary for 2 min then do it all again. If you draw the round you do that all again again! the motor will go from one extream to the next and back again in a matter of 10 min. At the Da round lots of cars were pulling out due to engine problems or failure.
    So i thought a descusion on "what 4A motor would be best for drift" would be intresting
    looking into things like "powerfull enough" and just as important "reliability"
    whats your experiance or opinion?
    JJ
    Ken
    Spearwood
    Most will tell you, none of the 4A.
    SR, 3S, F20, etc.
    But a AE92 smallport 4AG with 272 cams and high compression would be reliable enough, providing you with enough power (maybe not enough as those big hp cars) but you'll definately be having fun and always out there.
    性交を愛する
    Here we go...
    Veteran Konakid's Avatar
    Henry
    Eastern
    Seee ayyy bro
    Ken
    Spearwood
    elle has one?
    Senior Member OMG866's Avatar
    Nick
    Miranda
    lol ok well as far as reliability goes. 4age are awsome. even stock ones jsut make sure they have oil and they will go for ages. they also make big power IF YOU HAVE THE MONEY. i kno of a person that is close to have 360rwk in a 20v turbo. but the motor more than likely ows him over 35g. If you want cheap power jsut go SR. spend another 4 grand on it and it will drift all day everyday.
    Senior Member worked's Avatar
    ed
    tas
    wynyard
    whatever 4a has the best life support system (oil cooler, radiator, fresh oil, coolant, prepared well etc) would be my bet
    4a's love it tho, go forever, f*cking good engine
    miss my 20v, hate my ca
    NEAR MISS
    Senior Member Simon-KE70's Avatar
    Simon
    4ac for DA
    but as for drift being hard on the motor... well yes that part is true, however those who thrash cold engines deserve to have engine issues.... ive always warmed my motor up to operating temp (and oil is up to temp also) before thrashing... same goes for the diff and box....
    then once you park it in then go out again,... it takes all of 30 seconds of normal running (idling then leaving the pits, then the form up area and onto the track) and its back up to temp in no time.
    Senior Member orange32's Avatar
    Zac
    Redlands
    4agze
    I have 2 friends who drift with them. Both stock (front mount cooler and exhaust) and both will drift QR in third fine, without bogging down or being ruthless on the drivetrain and motor.
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    i wnet form 4agze to 4agte to next 4agte to next 4agte to built 4agte to 4aSR20 cut out the middle man put in an sr20
    AE86 THE BEST
  1. 4a-geu ecu pinout same as ae82 4a-ge?
    Last Post: 25th November 2009, 05:21 PM
  2. FS: Ae92 4a-gze 650$ or swap with fwd 4a-g
    By Mickey H in forum Car Parts For Sale
    Last Post: 26th June 2009, 07:16 PM
  3. Are Ae82 4A's the same as AE86 4A's?
    By Maxhag in forum Technical - Questions
    Last Post: 1st January 2008, 12:56 PM
  4. Unifilter Air filers, 4A-C Carb on 4A-GE manifold
    By asher in forum Car Parts For Sale
    Last Post: 15th June 2007, 08:16 AM
  5. 4A-GE head onto a 4A-C Block??!?
    By ironmonkey in forum Technical - Questions
    Last Post: 10th April 2007, 08:47 PM
