Results 1 to 10 of 10
Thread: my turbo smallport plans. what you think?
    Nic
    Mt Evelyn
    Default my turbo smallport plans. what you think?
    hey guys im in the process of freshening up the smallport 4age i brought. i plan to rebuild the bottom end with standard crank and rods then some acl race series piston, rings and bearings. i just plan to rebuild the head to stock(maybe some port and polish???). i am thinking about getting the block o ringed with a copper head gasket to ensure no problems. i am contemplating running a bigport tvis manifold as i heard somewhere some people run them to help bottom end power with a turbo set-up. and finally running a t25g. un sure what ecu to run i was thinking about a razorback one but cant find much info on them. what boost to run??
    anyway let me know if my plans are on the money or not.
    nic
    Senior Member Simon-KE70's Avatar
    Simon
    big port mani wont fit small port head so scratch that. dont even worry about o'ringing the block either. just machine all th surfaces and then run a quality headgasket. wouldnt worry too much about the head either, just make sure its in good condition.
    as for everything else.. go for it.
    your motor will handle whatever boost you want to run.... its all in the tuning as to if it can hold together or not.
    but that said. the T25g is shit and wont do much more then 14 psi without falling apart and even then thats right on the edge of the efficiency map.
    Nic
    Mt Evelyn
    what about a t28 bush bearing turbo? also i was going to use a manifold adaptor. or u think the tvis manifold isnt worth using?
    Simon
    no i dont think its really worth using.
    the t28 bush turbo (as found on ADM s14's and s15's) is still a good turbo and can be had for quite cheaply these days.
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    get a t3 bigport-smallport mani adaptor def get a bush bearing t28bb head will be fine and use toyota pistons not aftermarket junk. run 20psi make 180kw sik!!!
    should buy my turbo setup that would make your life heeps easier and cheaper!!!
    AE86 THE BEST
    Veteran shift_rook's Avatar
    SE Burbs
    definately, get eddies setup, then you can also say you have a professionalk dirft engine in ya car
    Nic
    Mt Evelyn
    nah eddie wants too much. im going to get gze pistons now. anybody got the part number for smallport gze piston and rings??
    Eddie
    sa
    brand new t28bb 1100 manifold 400 cooler 250= $1750 and thats without all the other pieces to make it all work adn im asking $1500?
    neway like i said b4 i got some near brand new gze pistons here did like 2 laps of the block before i realised the block was cracked, and brand new rings to go with them!!!
    all up the pistons are around 500 and rings 180 new from toyota
    AE86 THE BEST
    Seamus
    Milton
    There was a group on ebay (that sells MG parts of all things) that were able to do the ACL forged pistons for ~$700
    And i think your setup sounds good. Standard crank and rods are great, and the pistons you want to use can take a hell-of-a-lot of abuse.
    Don't bother with the O-ringing
    And also (as simon said) T25/T25g's are shit. T28 and upwards thanks.
    Boost depends on your turbo. No point running your turbo out of its' efficiency range. I.E. Don't push any of the standard T25/T28's over 15psi, the power gains will be minimal and you will just stress shit out.
    Although if you go a 'better' turbo, things might be different.
    Your engine should handle 250rwkw.
    Nic
    Mt Evelyn
    how much are you after for the piston and rings eddie? are they smallport ones? i have to find out wether i can run standard size pistons pretty sure the block is in fine condition.
  1. whats needed to run LT10s on turbo smallport?
    By Nic19 in forum Technical - Questions
    Last Post: 2nd May 2009, 01:35 PM
  2. stock smallport inlet with turbo?
    Last Post: 22nd April 2009, 09:10 PM
  3. smallport turbo manifold on bigport 4age
    By spaniel in forum Technical - Questions
    Last Post: 5th September 2008, 10:34 PM
  4. Phone Plans
    By The_81 in forum Offtopic Discussions
    Last Post: 1st August 2008, 09:41 PM
  5. Boradband plans
    By BouNCE-86 in forum Offtopic Discussions
    Last Post: 29th January 2006, 03:53 PM
