Results 1 to 2 of 2
Thread: diff help
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    Default diff help
    before yous all start yes i have searched just want a little info on diffs
    1. im looking for an f or g series diff which car is the best one to get it out of (i want the width of the diff to be close to the standard width as possible)
    2.did either diffs come with a 3.9 ratio
    also i heard that the g series is overkill im running an sr20det is this true or will it be ok
    EDIT forgot to ask do u need a custom tailshaft for the f series or can u use thetarago rear half
    Jonathan
    I think you want a diff housing from a RN40 HiLux from memory, G series 8", good width. (I could be wrong). Then you need to cut and weld the mounts for 5 link instead of leaf. Then select your ratio seperately, off any HiLux, lots available. The LSD is from the rear of most HiLux 4wd.
  • Similar Threads
    1. Wtb adm sprinter diff, diff centre or crown and pinion.
      By Ade_Mc in forum Cars or Parts Wanted
      Last Post: 31st July 2012, 12:00 AM
    2. T. Series diff 4.11 diff gears, ae86 bolt in half cage
      By armc89 in forum Car Parts For Sale
      Last Post: 25th June 2012, 09:47 AM
    3. WTB S Series Diff or Diff housing!
      By dtour in forum Cars or Parts Wanted
      Last Post: 12th September 2011, 04:59 PM
    4. 4.56:1 diff ratio E series diff
      By Clemo55 in forum Cars or Parts Wanted
      Last Post: 25th September 2008, 04:29 PM
    5. ke70 diff or ae86 standard diff
      By Roo in forum Cars or Parts Wanted
      Last Post: 22nd September 2008, 11:41 PM
