Results 1 to 6 of 6
Thread: RX7 adapter for bigger rotor's (276mm) 15 Rim
    Default RX7 adapter for bigger rotor's (276mm) 15" Rim
    This is only an expression of interest. and for a 1 off run only.
    other than that i can get out in touch with who i use and they will charge you whatever they want.
    AJPS sells RX7 caliper adapters, and i dont want to chop into his business.
    but i would like to go to a 276mm rotor from a 2000-2001 mini cooper
    So that means that i have to make a custom adapter, from the plans available on the net........ as such since ill be getting it done by a proper CNC machine, the more i get done, the cheaper it becomes.
    The Mini rotor is a 276mm diameter, 22mm thick, 64mm center hole. while the EG civic is: 262mm diameter, 20mm thick and 64mm center hole.
    DBA part number for the mini rotor is: Street:542SL (left) and 542SR (right). The S is for slotted, and the L/R is for side.
    Also available in 4000 series: 4542SL and 4542SR
    everything else for the upgrade is the same, just a different adapter and a different rotor.
    So would anyone be interested in a RX7 caliper adapter to take a bigger rotor.
    ADVANTAGES:
    Bigger, more heat distribution = less brake fade
    DISADVANTAGES:
    prob wont be able to run anything less than a 15" rim.
    so yeah let me know and ill try to organise it.
    if not i might just do it myself, or if it gets to hard AJPS here i come.
    Senior Member 4.5AG's Avatar
    Vener
    NT
    Lyons
    count me in
    Senior Member rallystanza's Avatar
    Jeremy
    Vic
    Straya
    Will these be made of steel and therefore engineerable, if made with correct material?
    Very interestedn pending a few things.
    yes, they will be fully engineerable. i will be doing this the long way, using the appropriate materials and a proper CNC machining factory.
    i am arranging for a quote to see if its cost effective
    Kevin
    Queensland
    North Lakes
    it sucks i cant open the files on my computer to see the drawings
    Senior Member Oly AE86's Avatar
    Oliver
    Logan Shire
    Free DWG Viewer available
  1. Front Brake Upgrade: RX7 4 Piston caliper and 276mm Rotor
    By Oly AE86 in forum Technical - Articles
    Last Post: 11th June 2014, 11:20 PM
  2. 3 Aluminium 135 degree pipe & 3- 2.5 silicone adapter
    By Seventy in forum Car Parts For Sale
    Last Post: 10th January 2012, 09:54 AM
  3. 15 inners for 2 piece rim
    By 4AGENT in forum Cars or Parts Wanted
    Last Post: 23rd June 2011, 12:09 AM
  4. Anyone got a spare 15 rim?
    By Tom86 in forum Perth & WA Events and Discussion
    Last Post: 12th September 2009, 05:40 PM
  5. Genuine 15 Work rims, rim wheel wheels
    By AE86.cn in forum Car Parts For Sale
    Last Post: 25th July 2008, 07:06 PM
