if kluger/prado motors werent so expensive that'd be a good one i recon
that dosent sound bad what diff should i run i snap axles with my 4age setup as it is so with that i would have to use a hilux diff or something aye
you mean prado/hilux 1GR ??
kluger is transverse camry motor
rb20 ?
20v?
there still expensive, been lookin for a dead one which i can't find, bloody stupidly tough toyotas, and the cheapest was a long motor and that was still 2500.
and rb20's arent worth the work or the money
yeah i just wanted to try something different but i guess the best thing would be stick with something thats tried and proven
nothin wrong with having ago mate, get out there see whats around u might find somethin that will work you may not but its worth havin a go its always worth havin a go
true true ill see what i can come up with
<div class='quotetop'>QUOTE (Dr!ft_Sh@gg!n_W@g0n @ Feb 19 2008, 05:13 PM) </div>also need to do major firewall and trans tunnel mods
try a 2vz/3vz/5vz 6 conversion
(v6 hilux ,camry)
should be able to get manual conversion from a 4x4 and 2wd hilux...........
4x4 bellhousing to w58 box and use standard 4x4 clutch setup and slave cylinder etc
prob do one for $3500 no labour
these engines make between 120-160 kw stock
[/b][/quote]
I have seen it installed in an ae86 without a scratch to the firewall... so it may be doable
