Results 1 to 10 of 12
Thread: RWD waterpump part number needed, please help
    Veteran stahlz_ae86's Avatar
    Paul
    Default RWD waterpump part number needed, please help
    Hi,
    Converting a FWD 100KW smallport 4A-GE to RWD format and don't like the shitty untidy remote themostat housing idea.
    I've got a couple part numbers but all toyota could tell me was they're water pumps which was not helpful at all
    The numbers I have are...
    16110-19155
    Which is apparently "complete 4A-GE" around $80.40 +GST according to the part numbers thread.
    or
    16100-19095
    Which is apparently the entire waterpump assembly including thermostat housing etc (but no thermostat)
    When the dude at Toyota ran the latter number he said it was around the $190 mark from memory.
    Can someone please help as I don't wanna throw 190 bucks at them only to find it's no good to me as they are unable to re-imberse for the ordered in part.
    ive order'd the exact same part number on the assumption that im getting the whole assembly...hasnt arrived yet so i cant confirm 100%
    Paul
    When did they say you would get it?
    They told me thisarvo they had it in their city one and could have it out to my area my monday arvo.
    Let me know how you go with it please, I need the outlets for the hoses to go on too so I hope this is the part.
    Quote Originally Posted by stahlz_ae86 View Post
    didnt order locally...got a whole bunch of stuff straight out of japan...works out cheaper
    still prolly a week and abit away....
    Paul
    Cool cool, let me know when you get it I'll have the motor out of my van by then i hope and will have started the other conversion shit by then like pedal assembly, gearbox, tailshaft, fuel system etc.. water pump can wait until last.
    Jonathan
    Corrected:
    16110-19155
    is the waterpump, probably just the front, maybe both halves. (Hard to see in diagram)
    16100-19095
    is the same waterpump, but you get the gasket kit also. You don't get the thermostat housing or the top outlet. Just the pump, gaskets, and O-rings.
    If you look on the EPC the housings are shown, which causes confusion. But they are only shown as a dotted outline, not a solid line.
    Quote Originally Posted by Jonny Rochester View Post
    I think you will find that
    16110-19155
    is the complete waterpump, both halves.
    16100-19095
    you can say that again, but now looking back at the diagram i can see wat you are refering to cheers
    Veteran Nikkojoe's Avatar
    Tom
    16100-19095
    I got this one, contains what Jonny said. The gaskets are the proper metal gaskets and orings.
    16268-16011 for the bypass pipe (i beleive rwd 4age), if not use 4ac and shorten, and if you wish make a groove for the oring to sit in (or silicone one end in).
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Or just use RWD 4AC gear and save yourself a packet.
    Tom
    Or what Golberg said, just need to modify the 4ac pump a little to clear the 4age timing cover backing plate.
  1. 4age rwd alternator part number
    By Deeken in forum Technical - Questions
    Last Post: 30th September 2011, 08:34 PM
  2. RWD waterpump onto FWD engine
    By driftnick13 in forum Technical - Questions
    Last Post: 23rd January 2009, 05:47 PM
  3. TRD .5mm rwd head gasket part number required...
    By shelldrake in forum Technical - Questions
    Last Post: 11th August 2008, 09:21 PM
  4. Part number for rwd water pump
    By Rich_86 in forum Technical - Questions
    Last Post: 13th November 2007, 09:18 PM
  5. 4ac waterpump same as 4age rwd waterpump?
    By simonster in forum Technical - Questions
    Last Post: 25th October 2007, 10:11 PM
