last time i check sc oil was meant to be 0w. if you can find a single weight full syn oil you may get away with 10w.
Ring holden
the have oil for the old eatons sc
Hey guys,
I've been looking around for some super charger oil of any kind but no luck, so wondering if it's ok to use fully synthetic oil ?
how often would you have to change the supercharger oil?
motul make 0w oil for super chargers
not cheap tho
shouldnt need to be changed that often
hrmm I'm using something pretty thick then..... i should change mine, also its only there to lube gears? so shouldnt really need to be changed?
I'm using 75W-80, anything lower will be alright i reckon, i hear the toyota stuff is almost like water density
ohh and there was something about not using full syn....
What would be so bad with running 10w-30 oil ? too thick ?
The SC oil just lubes the gears connecting the lobes and a couple of bearings.
I'd be happy to run olive oil in the thing.
