Results 1 to 5 of 5
Thread: Ae86 rear shocks - what is every one using
    Senior Member AIROCOBRA's Avatar
    Bob
    ACT
    Weston
    Default Ae86 rear shocks - what is every one using
    Hi , I have a ADM AE86 (4AGU ) , WITH LOWERED 6 KG REAR COILS. Just bought it . THE Rear KYB adjustables are shot . It has CUSCO 8KG front coil overs . so I am after a shck that will give me rear grip as I am going to hill climb it.
    Regards Bob
    Senior Member 45aken's Avatar
    Marko
    Might want to lower your spring rates a little if you want to hit the hills.
    kyb's again or trd blues are the standard i guess.
    the kybs will perform better with a lower spring rate too.
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    trd/kyb shocks and 4kg springs would be ideal.
    User fantapants's Avatar
    Pat
    i dont get it.
    trd and or kyb right? but lower the spring rate? The shocks are totally differnt, incredibly differnt and have a MASSIVE difference to the handling of the rear end.
    I have run both chocks in the same coilover sstem with the same spring. The kyb on level 8 was still soft enough to bottom out. The trd on 2 is still harder than the kyb. The kyb at its hardest allowed for heaps more body roll and suspension comression than the trd. The trd's are VERY stiff. This is NOT a result of the springs!!!!!
    I rate the feeling of my trd's howvere for a grip orientated car, bilsteins would be my first choice, see ajpa, or kyb The trd's can be very good, but i recon they are too stiff for a ruff track. Super smooth no probs, but anything with a gnarly bumps or shit surface...
    one of the fastest hillclimb 86 in britain runs standard kyb coilover set from t3 with a 6kg spring.
    06/07/2011
    Jonathan
    You may have to adjust a shock up tighter as it slowly wears out, so it could be hard to compare 2 second hand models.
    I have Koni Sport (yellow) to suit Startlet/Paseo. Only because there were cheap.
  1. Coilover Sale - AE86 Front + Rear Springs & Shocks - S13 Rear
    By Skid_KE70 in forum Car Parts For Sale
    Last Post: 10th October 2012, 03:07 PM
  2. [SA] AE86 Rear Shocks/springs Rear Strut Brace
    By Ham86 in forum Car Parts For Sale
    Last Post: 4th March 2012, 07:29 PM
  3. Replies: 12
    Last Post: 8th October 2011, 03:51 PM
  4. AE86 rear Bilsteins - shocks only
    By johnny_08 in forum Car Parts For Sale
    Last Post: 8th April 2009, 10:05 PM
