Results 1 to 7 of 7
Thread: 20v ITB's on beams 3sge
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    hi all, will be doing a beams 3sge conversion in the not too distant future and as i have to mod the intake to fit it into an ae86 i am thinking about adapting a set of s/t 20v quad throttles onto a custom intake setup for it
    are the 45mm throttles going to be big enough for it?????
    incase your wondering ill be using aftermarket ecu so there will be no problem with what tps to use or any afm problems or anything like that
    cheers, brendan
    MY JZX83 (clicky)
    Veteran deleta's Avatar
    Callum
    Queensland
    Wynnum
    from what i here the black top ones are bigger, tho also the sr de ones from gtirs are even bigger. so id go the sr ones if i was you just so you dont constrict the flow, but then agian ive been wrong b4 see how you go.,
    Seamus
    Milton
    go BT quads, they'll be plenty big even for most turbo applications
    no need for 'custom' anything though, people have already made adaptors to fit them to most 3SGE's. danstoy.net, yahoo JP, just to name a few
    hope that helps.
    ^ Clicky clicky!
  • #4
    Seamus
    Milton
    its good that you asked
    my maths might be farked, but blacktop throttles are 45mm
    if you do the area of four of them, it comes to be the same as a 90mm single throttle body (89.98 to be exact)
    so that should be HEAPS for just about ANY motor.
    ^ Clicky clicky!
  • #5
    Anthony
    The TRD quad throttle kit is based on blacktop 20V items. But they bore them out to 50mm. When there is no plenum and the throttle is closer to the valve it works a little differently so you can't just equate throttle areas like that unfortunately.
    The TRD kit is fairly well priced from memory. Otherwise contact Glenn (CelicaRA45 on toymods etc) as he makes them for some very high powered NA beams motors.
  • #6
    <div class='quotetop'>QUOTE (Anthony @ Mar 3 2008, 12:39 PM) <{POST_SNAPBACK}></div>
    The TRD kit is fairly well priced from memory. Otherwise contact Glenn (CelicaRA45 on toymods etc) as he makes them for some very high powered NA beams motors.[/b]
    Yeah CelicaRA45 is selling some Quads on the Altezza forum ATM summary below:
    <div class='quotetop'>QUOTE (CelicaRA45)</div>
    I have some 3sge altezza inlet manifolds to suit quads, a 48mm quad set and also 50mm quad sets for sale. also have the 2 stage injection units that bolt to the quad sets as well. These will all fit the 3sge altezza motor, but you would need an after-market ecu to run these. The Quads are made by Kayza in sizes 48mm and also 50mm which bolts onto the inlet mainofolds. forgot to mention that these are bigger than the TRD quads but have the same bolt pattern as the TRD item as well.[/b]
  • #7
    Brendan
    NORTHSIDE YO
    mmm some interesting info there guys thanks heaps, the reason i say i want to go custom gear is coz my uncle does all that kind of shit and will let me use all his gear and guide me through how do do it, thus me learning more as thats what i do conversions for, learning and fun
    so from what i have read silvertop throttles will be big enough for my application
    ill be trying to keep the runners as simple as possible to allow better flow etc, anyone got pics of theese manifolds for sale for them??? i might go any have a look at the websites that have been posted to try and open my eyes on this a bit more
    cheers for the answers guys
    MY JZX83 (clicky)
  • Similar Threads
    1. Replies: 12
      Last Post: 29th November 2010, 09:00 AM
    2. Quads for beams ( 20v or 3sge)
      By DR86TY in forum Cars or Parts Wanted
      Last Post: 9th November 2010, 10:14 PM
    3. bt 20v v's 3sge beams
      By dehney in forum General Topics (No Technical Questions)
      Last Post: 17th July 2009, 09:12 PM
    4. wtb 20v ITB's in good condition!
      By omy in forum Cars or Parts Wanted
      Last Post: 27th June 2008, 07:40 AM
    5. 3sge altezza BEAMS inlet manifold to suit 20v quads
      By Celica RA45 in forum Car Parts For Sale
      Last Post: 1st July 2007, 10:16 PM
