Results 1 to 10 of 18
Thread: proper fucked
    User fantapants's Avatar
    Pat
    Default proper fucked
    sooo trying to remove my sump or some looksie...
    got to the last allen key bolt at the back of the alloy sump pan, and the ball joint on my allen key has snapped off.
    yes the ball is still in the bolt head......
    whats the best way to go about getting this out?
    was getting rewady to try and drill out, but i dont have nay drill bits long enough....
    cheers guys!
    pat
    06/07/2011
    Senior Member Chairs with flares's Avatar
    Jeff
    East...
    Magnet on a stick?
    Tweezers?
    J.
    Veteran drift kid's Avatar
    Glossodia
    yeh, is it a very tight fit? cause u might b able to jiggle it out other wise drilling is looking to b the best option.
    Pat
    yeah they are a tite fit.... drilling is looking like the only way
    06/07/2011
    Jeff
    East...
    See if you can get a reverse/left handed drill bit for undoing snapped studs.
    The bit catches into the metal and unscrews the bolt.
    J.
    Pat
    dont think i managed to actually get the bolt to loosen, just snapped the ball off the end. revers thread may work, but only if i loosen the bolt any...
    06/07/2011
    Veteran shift_rook's Avatar
    SE Burbs
    yeah either drill or get some vice grips round the actual bolt undo it and just buy another one...
    Senior Member dave2221's Avatar
    pop the allen key out and try again...
    rare earth magnet may do the trick, it will certainly have enough force if your allen keys are magnetic.
    Try tapping the broken tip with a hammer and screwdriver to loosen it in the bolt.. remove with a magnet and try again.. if not unfortunately its drills
    Pat
    pop the allen key??? if it was tight enough in the block to snap the ball end off a good quality allen key, maybe its jammed....
    hmmm note to self, cant drill at night...
    06/07/2011
  1. DA Fucked again...
    By ae8zn6 in forum The Drift Channel
    Last Post: 17th May 2010, 09:58 PM
  2. Proper Throwout Bearing
    By Dish in forum Technical - Questions
    Last Post: 23rd March 2009, 11:50 AM
  3. So i think my cars fucked
    By quadeyquade in forum Technical - Questions
    Last Post: 26th January 2009, 10:48 AM
  4. gearbox fucked?
    By dr1ft-pig in forum Technical - Questions
    Last Post: 9th October 2006, 03:52 PM
  5. My first proper magazine appearance
    By indi in forum Offtopic Discussions
    Last Post: 22nd November 2005, 09:59 AM
