Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 32
Thread: Z10 series soarers
    Veteran slydar's Avatar
    Dimitri
    Default Z10 series soarers
    this is my bros. we've owned a few now between ups but this is the best so far.
    has 60mm shortened struts, coilovered with agx inserts and 450lb springs.
    rear are just shortened stock springs with trd ta63 short storke shox.
    wheels are 16x7.5 F 16x8 R +20 offset, rear has 25mm bolt ons.
    has rcas (needs bigger ones lol), gonna put some longer lcas in it next week.
    pretty psyced on it really, im building one with a 3S and 15x9s, should be on the road real soon.
    78's
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    theyre awesome looking cars. i like the rareness factor of them too
    got pics of yours? 3sgte?
    is that your ae86 next to it?!
    Dimitri
    its not done, pics in a week or 2. you can actually see mine through the back window of my bro's.
    mine will be a gen1 3sge+t. they only have 9.X:1 cr anyway, ill just be using a t25g and about 10psi max, only want 140/160rw. using a stock gen2 gte intake (center entry crossover style) in the tall soarer bay that shouldnt need modding.
    water pipe up the exhaust side beside the cam cover, COP, got a dizzy cover for it (and gen2 dizzy) will be using all st141 mounts, including the x member brackets ill cut off and weld onto the soarer, so mounting will be easy, that will set the height, then ill just set the length by whatever works with the stock manual x6 tail shaft and sa63 w55. its a big bay and a pretty small motor, so should be easy.
    oh, and adaptronic of course
    should actually be a pretty easy conversion i think.
    just have to go pick up the mr2 alt' bracket.
    ill be setting it up NA first. with a 2.5" exhaust which ill keep with the turbo, will be too low to fit 3".
    78's
    Senior Member shichi~'s Avatar
    Ethan
    North Suburbs
    love these! make it phat
    Senior Member Danzo's Avatar
    Danzo
    Cheltenham
    i like you.
    DTF - Danzo Technical Factory
    Veteran driftke70's Avatar
    Ryan
    Buderim
    those wheels i fitted up for ores are finally turning,
    i like the shape of the 10, not so much the others, like the idea of a 3s, the more the merrier.
    wheelfriends.wordpress.com
    Veteran Konakid's Avatar
    Henry
    Eastern
    Looks good dude, at all japan day on the weekend a dude had his IPRA RA40 there, runs a stock 185 3sge + T and makes 220rwkw on 19psi with a 36mm inlet restrictor!
    Im definitely keen to go 3S + T after seeing that kind of figure.
    Dimitri
    yeah, na CR + cams always helps. these gen 1s are fucking everywhere at wreckers down here.
    they do have their oiling issues but theyre fine if maintained. i heard mine running, wrecker kid was running errands in it cranking some hektic neutral dumps.
    if i do ever manage to damage the bottom end, i think ill just go 5s bottom end. pretty sure a 2s rwd flywheel will bolt up to a 5s.. but i need to check. either way i think its a very over looked budget set up.
    so far its cost
    $120 whole engine
    $100 manual flywheel and double row spigot bearing (cheers af300e)
    $45 for an mr2 alternator bracket
    $325 (delivered to my door) for a w55 with 2s bell
    swapped the gen1 intake with a gen 2 with some guy on toymods.
    78's
    Anthony
    ha im going to do one of those lists too
    edit: OK late rule change, im out\
    Dimitri
    yeah either way you dont have the lasre alpha version anyway.
    78's
  1. wtb T SERIES TAIL SHAFT or Complete W Series Gearbox Conversion
    By Vaughn in forum Cars or Parts Wanted
    Last Post: 11th December 2012, 09:21 PM
  2. F series, G series, T series 4link diffs ready to bolt in also W58s
    By sumfancyname in forum Car Parts For Sale
    Last Post: 11th August 2011, 09:39 PM
  3. Replies: 3
    Last Post: 26th April 2011, 12:30 AM
  4. Replies: 4
    Last Post: 18th March 2011, 05:40 PM
