Results 1 to 3 of 3
Thread: AE86 Trailing Arm Bush Sizes ??
    Pat
    Jannali
    Default AE86 Trailing Arm Bush Sizes ??
    Hi,
    May Amaroo Clubman has AE86 drivetrain and I thought had AE86 Upper and Lower trailing arms.
    I just ordered some Nolethane bushes for Rear Upper and lower trailing arms and they appear to be wrong size, just want to confirm what size they should be as believe I may not actually have AE86 trailing arms after all.
    My arms have:
    6 bushes Diameter 26mm by 31mm long with crush tubes that take 12mm bolts and
    2 bushes Diameter 20mm by 31mm long with crush tubes that take 10mm bolts
    Nolethane Kit has:
    4 bushes/kit 2 kits all same size
    The 2 piece bushes are designed to fit Hole Diameter 30mm by 40mm long (not including flange size) i.e.
    So which is correct for AE86 ????
    Hope sizes make sense
    Thks for any help
    Chrs Pat
    Jonathan
    All 4 links (8 rubber bushes) on an AE86 use the same size bushes. They use 12mm bolts.
    Pat
    Jannali
    Thks Jonny obviously not AE86 then, I better start searching.
  • Similar Threads
    1. AE86 lower trailing arm bushes
      By matt99 in forum Cars or Parts Wanted
      Last Post: 25th June 2012, 01:06 PM
    2. Trailing Arm Troubles
      By svenmate in forum Technical - Questions
      Last Post: 29th August 2010, 10:33 AM
    3. Trailing arm bush options
      By starni_boy in forum Technical - Questions
      Last Post: 5th April 2010, 01:44 PM
    4. AE86 trailing arm/4-link .. yep, just one, any one
      By 70XIN in forum Cars or Parts Wanted
      Last Post: 11th March 2010, 06:43 PM
    5. HELP upper trailing arm
      By i2obert in forum Technical - Questions
      Last Post: 10th October 2009, 01:48 PM
