Results 1 to 5 of 5
Thread: rear diff
    Senior Member Stej's Avatar
    Steve
    Default rear diff
    can a faulty diff cause the rear end of the car to sway a bit? I have checked all my suspension, but still the same problem. Has anyone else had the same problem or could give some advise?
    its got a TRD 2way lsd
    Jonathan
    Bushes on the panhard rod. (I think this should be called the anti-sway bar. And I think the sway bar should be called the anti-roll bar.)
    Steve
    so there is no way the diff can cause the rear end of the car to float around like it is?
  • #4
    Timmy D
    North
    Default panard rod
    no the center will have nothing to do with it. replace your bushes like J.R. said or get an adjustable panard rod with rod ends. so if you ever lower the car you can re-centre the rear end. The rod ends will make sure there is very little movement.
    JJ
  • #5
    Steve
    hey i have just had the car fully checked out the panhard rod, trailing arms the whole rear end checked, the mechanic thinks its a driveline problem there is play in the centre bearing is that normal?
  • Similar Threads
    1. Replies: 6
      Last Post: 18th March 2009, 07:47 PM
    2. t-18 rear diff - bris
      By notdk in forum Car Parts For Sale
      Last Post: 12th March 2009, 04:37 AM
    3. AE95 rear diff
      By riojin in forum Technical - Questions
      Last Post: 27th January 2008, 01:42 PM
    4. DIFF / REAR END
      By winslow in forum Cars or Parts Wanted
      Last Post: 6th December 2007, 10:14 PM
    5. Rear Diff
      By keto in forum Technical - Questions
      Last Post: 21st August 2006, 01:21 AM
