Results 1 to 5 of 5
Thread: Can anyone recommend...
    Senior Member Beck's Avatar
    Andrew
    Default Can anyone recommend...
    a good mechanic in Sydney that actually knows a bit about lightly modded (4age daily) AE86s?
    I'd prefer someone that does really top work as opposed to someone who will work cheaply. Up near Hornsby would be ideal, but I'm happy to travel a bit for a decent mechanic. Pulling my hair out with recommendations from friends or whatever and taking my car in only to have it not properly fixed, or repaired to some dodgy Holden-spec consumer parts crapfest. If you know what I mean...
    Thanks in advance.
    Gone
    Joel
    Picton
    Hey champ, I know what u mean! I'm very hesitant to take my cars to any mechanic because alot of the time u don't get what u pay for. I have 2 tuners who I would use. But if u don't mind me asking what is it u need done?
    Andrew
    Well, at the moment my new LSD is making some pretty awful noises... I've recently had the rust cut out, welded, a re-spray, and some mechanicals done at the same time. One of those mechanicals was swapping the ADM drum for a disc rear end with (I was told) a Kaaz 2-way. Have had the car back for a week or so, and the diff is cactus. Shuddering on takeoff, whines like a bitch, and a crazy grinding noise during deceleration.
    So that's the immediate issue, but I'm also looking for someone I can use as a regular mechanic for the stuff that I don't have time, inclination or tools to do here. Basically anything more involved than oil changes and brake pads, etc.
    Also would like to get some engine stuff done - mostly fuel system stuff - and possibly get some advice on suspension. So pretty much everything, heh.
  • #4
    john
    nsw
    liverpool
    hi there.
    i have said it on another thread in the nsw section .
    sprinterman68 - his name is john . i would rate him one of the top sprinter mechinac around in nsw. 0414531273. most honest guy ive met. i have had work done from him and very pleased . only problem is he is loacted at penrith .
  • #5
    Andrew
    So, just call him up cold and say hey I need some work done? If so, thank ya, I'll give him a call.
  • Similar Threads
    1. Tyres ... What do you use/ recommend?
      By Faceplant456 in forum Technical - Articles
      Last Post: 6th February 2010, 08:25 PM
    2. what spring rate you recommend?
      By AE86.cn in forum Technical - Questions
      Last Post: 27th March 2008, 12:50 AM
    3. Recommend Engine Oil?
      By OMG866 in forum Technical - Questions
      Last Post: 25th February 2006, 05:27 PM
    4. what6 clutch u recommend
      By MkII in forum General Topics (No Technical Questions)
      Last Post: 22nd February 2006, 01:40 PM
