Results 1 to 4 of 4
Thread: 4age oil system.
    Warragul
    Default 4age oil system.
    Hi, guys new to the forum.
    I need some help with my 4age build-up.
    I have always used bigport and I am running into a few issue's,
    building a smallport engine, I have a 7rib block that I have brand new internals in but it has no oil return pipe or squirters like my other block.
    Can I still use a smallport head on this????????
    Please help
    Warragul
    Ok did any bigports come out with a 7rib block???
    Veteran slydar's Avatar
    Dimitri
    youve got an early ae92 block.
    the drain/breather at the back of the head you can plumb into the sump id say, as long as its above oil level. you may even be able to just block it off. as the oiling for the head is the same as BP, oil drainage wont be an issue. it is my understanding that external connection is more of a breather than a drain, though obviously some oil does return down it.
    the oil squirters i am not so sure on. i guess it depends what rods/pistons/wrist pin set up you have/intend to use maybe.
    the squirters to my understanding serve 2 purposes. one is piston cooling, the other is maybe oiling of the little end (full floating in any oil squirter type engine, press fit in all non oil squirter blocks)
    lo rolla might be able to comment. pm him a link to the thread. he's an apprentice engine builder.
    78's
  • #4
    Warragul
    Thanx heaps slyder.
    Yeah my idea was to run a hose into a small oil catch can that would sit a few mm above the pipe and any excess could just run in and back out as it wants.
    I just wanted to know if it was super important thanks!
  • Similar Threads
    1. Replies: 31
      Last Post: 28th August 2013, 04:18 PM
    2. 4A-GE oil system
      By Group A in forum Technical - Questions
      Last Post: 21st June 2010, 05:38 AM
    3. 4age engine oil / T50 gearbox oil
      By pogi in forum Technical - Questions
      Last Post: 27th May 2009, 11:27 PM
    4. 4age OEM Oil Cooler System/Setup for $80
      By thanhngo in forum Car Parts For Sale
      Last Post: 21st August 2007, 10:46 PM
