Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
Thread: RWD JDM 16v engine..... EOI
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Default RWD JDM 16v engine..... Price dropped
    Price Drop.. as low as it will get ---- > $900
    Edit - its now officially for sale, will be removed from car this w.e
    As I have my 86 off the road at the moment and its not been driven, I have been thinking of pulling out the engine and getting it ready to do my 20v conversion.
    This is an EOI as its not quite ready to sell (as its still in the car), and wont be coming out just yet unless I take a deposit from someone.
    Included will be:
    1 JDM 16v with 250XXX on the clock. Please take note - posted this further down but some may miss it. (I'm not even sure it has done 250XXX, it is just a generous assumption as I really have no idea, (probably a lot less to be honest) just going off the odometer (but this of course would not tell shit as it once wound the kays off a 4ac before it was converted), it still runs great although the shims need adjusting or the valve springs need replacing (has been like this for 2 years or so now and Ive never had a problem) starts everytime and dosnt blow smoke.
    (although Id suggest refreshing the head)
    Also the full engine loom and ecu, MSD Blaster ignition coil, KLS 12mm ignition leads, NGK platnium plugs, standard RWD exhaust and inlet manifolds, new dizzy rotor, possibly a full exhaust system (not sure on that one yet) drift pod. I think thats about it.
    the only thing it wont include is the alternator or bracket.
    it has a few minor oil leaks (sump gasket and the cam seals I believe, hasnt worried me yet though.
    No gearbox, flywheel included though but no clutch.
    Full cooling system including radiator also if the buyer wants it.
    Edit - forgot to mention also that it has always had regular oil changes (3000kms or less each change) with penrite hpr15. Just recently switched to nulon oil with the last change (which has seen less than 10kms of driving)
    $1000' now $900
    Located Brisbane - southside.
ID:	294   Click image for larger version.
Name:	You looked.jpg
    BENT MECHANIX - Garage 20:
    Niz
    South~Slide Briz
    bump n' grind
    Niz
    South~Slide Briz
    possibly pulling this out of the car this w.e, started removing things last night...
    Niz
    South~Slide Briz
    this will be coming out this w.e for sure so its officially for sale.....
    Niz
    South~Slide Briz
    ok just pulled it out 1/2 hr ago so its ready to go.
    Willing to ship also if any interstate people are keen.....
    Niz.
    Niz
    South~Slide Briz
    up.....
    Junior Member luke.t.'s Avatar
    PM'd.....
    best price you can do??? im in brisbane so let me know
    Niz
    South~Slide Briz
    fresh bump..
    性交を愛する
    Big Port or Small port?
  1. 4age 16v rwd engine package
    By pen15 in forum Car Parts For Sale
    Last Post: 13th May 2013, 10:50 PM
  2. WTB Alternator bracket off a 16V RWD engine:
    By no fame in forum Cars or Parts Wanted
    Last Post: 15th August 2010, 08:42 PM
  3. 16v bigport RWD engine
    By sundee in forum Cars or Parts Wanted
    Last Post: 25th July 2010, 05:01 PM
  4. WTB: RWD 16v Complete Engine Package
    By Dan_AE86 in forum Cars or Parts Wanted
    Last Post: 14th July 2007, 11:43 PM
