Results 1 to 6 of 6
Thread: japan import specialists
    Default japan import specialists
    Does anyone know of a repairer which specialises in japanese imported cars? I'm trying to get a roadworthy for my trueno so I thought I would first take it in to a mechanic who will be able to tell me exactly what has to be done for it to get a roadworthy. Preferably someone in the northern suburbs
    Senior Member JinxD's Avatar
    Ash
    what do you need a hand with exactley?
    i just put a trueno through regency myself with the help of a workshop its not that hard.
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    PM me with your email address, I got a fact sheet from regency for starters.
    Side intrusion, with sign off to ADR29 with evidence.
    ELR seatbelts for front and rear outbound seats.
    Child restraints to ADR 34A
    1st Jan 84-31st Dec 85 do not require a catalitic convertor be fitted.
    Then the rest for roadworth, no chassis damage, stock ride height, effective front and rear brakes, no leaks either oil or water/coolant. Trim fitted to areas near passangers, Inner guards fitted to front guards, lights all working, windscreen washer working, no structural rust.
    You can pretty much do everything yourself even manufacture your side intrusion bars, but you do require sign off for the bars by a chartered engineer.
    Also located NE Ad.
  • #4
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    go see jazmac performance!!!!Jazmac Performance, 24 Oborn, Rd, Mount Barker, Sa, 5251
    AE86 THE BEST
  • #5
    when you say lights all working does that mean that the inside lights or just the headlights, brakelights, etc? do the popup light retraction mechanisms have to work too?
  • #6
    dan
    adelaide
    adelaide
    if it worked from factory they would want it to work now
  • Similar Threads
    1. Sprinter Specialists
      By shift_rook in forum Melbourne & Vic Events and Discussion
      Last Post: 17th December 2012, 12:21 PM
    2. Aftermarket Parts Specialists
      By Mattysshop in forum General Topics (No Technical Questions)
      Last Post: 15th June 2008, 08:26 PM
