Results 1 to 7 of 7
Thread: Knocking from camber top
    Senior Member ke70 xx's Avatar
    Troy
    Woody
    Default Knocking from camber top
    Got this knocking in my front right coilover coming from the camber top nut at the very top. It seems to be moving about 2mm. It is very annoying driving around and makes me think somethings going to fall off.
    I reckon i could fix it with another washer or something like that but I cant get it off because it spins with the shock. Was wondering if there is anyway to get it off without using a rattle gun cause I want to fix it at home because its easier. Or if anyone has access to a rattle gun and they can just loosen it for me. Let me know because want it fixed asap.
    Cheers Troy
    Quote Originally Posted by MINIHORSE View Post
    "if i ever get another 86 i think it will be a track only car"
    Tried that....failed.....you will too....its like sleeping next to a supermodel everynight and only getting to nail her 5 times a year
    Member Jase86's Avatar
    Jason
    Melb. S.E.
    Try wrapping a bit of rubber(ie a bit of old inner tube) around the shaft and using a pair of multigrips or vice grips to hold it. It shouldnt really knock unless the nut isnt done up properly or the bearing has flogged out. In which case I dont think a washer will really help.
    "go forth young man, and if it has more..... pull fifth"
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    this happened to my mates front end after he hit a gutter, i figured the bearing in his cambertop is knackkered ? has a bit of play and now his tophat spins aswell, like u can spin it while its on the ground n all
    Veteran blair's Avatar
    Blair
    Sheldon
    Alex
    Wagga Wagga
    Seems strange that the other side is fine but this one is knocking. Do they both have the same setup, ie, no extra spacers on the other side? Could be flogged out bearings as the others have said if they are both the same. Vice grips/multis and rubber will work to hold the strut.
    Troy
    Woody
    Thanks for comments. Except dunno if blair is hating on me or actual trying to help but dont care. Tried tightening with spanner but just kept turning so tried the rattle gun at work and it tightened it more making the knock go. Realised it was something I did wrong. Thanks for help. Cheers Troy
    Blair
    Sheldon
    nah man trying to help
    its what i used to get mine off in a desperate situation.
    its like a oil filter removing tool, but smaller.
    you pull the rubber tight so you have a little loop and then use the serated edge to make it really really tight, turning in the opposite direction to the nut! presto!
  1. Camber Top Studs
    By Jono.C in forum General Topics (No Technical Questions)
    Last Post: 16th February 2012, 12:53 PM
  2. FS strut brace, cusco camber top, neg camber RCA's
    By ae71 in forum Car Parts For Sale
    Last Post: 20th April 2009, 04:14 PM
  3. Camber Top
    By loc33e in forum Cars or Parts Wanted
    Last Post: 15th August 2007, 10:28 PM
  4. Camber top washers
    By upgarage in forum Technical - Questions
    Last Post: 21st June 2007, 08:43 AM
  5. Camber top??
    By Poobrown86 in forum General Topics (No Technical Questions)
    Last Post: 6th March 2006, 05:17 PM
