Results 1 to 10 of 10
Thread: Anti Rust device....
    Senior Member RolandGTV85's Avatar
    Roland
    Bassendean
    Default Anti Rust device....
    I'm seriously concidering buying one of these but I'm not yet convinced they actually work. Has anyone actually used or had experience with one of these or something similar?
    http://www.couplertec.com.au/product/carsystems.html
    Member SR_andy's Avatar
    Andrew
    Heritage park
    hey champ i work at nissan and see a heap of people running these kits that come into work. they all seem to work as far as i can see. my basic understanding is that it puts a positive charge through the body which in theory stops the oxidization ( bad spelling ) occuring. not sure if that is the same way that kit works. but basically from what i have seen they seem to work. hope that helps
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    i've seen this a long time ago but wasnt too sure on it. would be interesting though
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    htese havent been out for more than maybe 20 years so go figure out how they are tested?? best way to prevent rust is cavity wax on the inside of all the panels so no water will get to panel joins and hahve drain holes so water can escape
    or fish oil that has been around since the start of cars!!!!!
    AE86 THE BEST
    Veteran Nikkojoe's Avatar
    Tom
    The theory is correct, pretty much what SR_andy said. They would work, but on newer cars its not really going to be needed. Automotive assembly techniques are much better (since mid 90's) and its very hard to find cars that start rusting. Most cars in the 70's to mid 80's would rust within 5years (depending on the environment).
    Cheap effective ways are to use cavity wax and fish oil as fast eddie said. Keep away from salt water.
    Senior Member Marco's Avatar
    Marcus
    Jindalee
    yes. they do work. don't reallt see the point in using one unless you are going to strip the car back to nothing fix all the rust then keep it for 20 years. but i know that people that use them on fourby's that go on the beach definately see results. after seeing under a car that hasn't used one then one that has go one it's enough to make you wanna run out and get one.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Quote Originally Posted by Nikkojoe View Post
    Unless you buy a Falcon, I know a couple of people who have had major rust work done under the 5 year new car warranty (cars bought after 2003 that is). Certainly wouldn't expect it from a Toyota though.
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    guess its where ur preventing rust ? as some said fish oil is a good option, my panelbeater is taking my splash guards out and i asked him to put fish oil inside but he said downside is it will smell like fish for a month inside ur car, he said deadening does it fine.
    Tom
    Their are always going to be defects when manufacturing cars, mainly its rust that has started out with a scratch during the assembly of the vehicle. No one in my family (with 1-10year old cars - falcons and holdens) have had any rust issues, some of which live near the beach. As said environment also plays a big factor.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    they dont work and cant work, look at "dans letters" for why. I have seen first hand testing and it didnt do anything more than make funny high pitched noises. Nothing quite like a back to back test with two sanded and salted panels next to each other.
  1. Wanted: rust free or minimal rust ae86 body shell rolling or not.
    By buster86 in forum Cars or Parts Wanted
    Last Post: 6th January 2011, 11:02 PM
  2. towing device.
    By redsprinter in forum Sydney & NSW Events and Discussion
    Last Post: 14th August 2009, 07:33 PM
  3. ADM rear lights, standard ADM steering device
    By roger roger in forum Car Parts For Sale
    Last Post: 30th January 2008, 07:23 PM
  4. Anti theft
    By blue86 in forum General Topics (No Technical Questions)
    Last Post: 21st August 2006, 02:39 PM
  5. Fuel saving device
    By 86sp in forum Offtopic Discussions
    Last Post: 28th September 2005, 08:55 PM
