Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: upgrading stand ae86 lights
    Jamie
    Default upgrading stand ae86 lights
    after having my sister (alot newer car) car while my ae86 was off the road it has made me realise how shit the low beam lights are. Now i find am driving around with my high beams on just to get some light on the road. what have you guys done to upgrade the low beam to get better light. i have already put higher watt globes in but it has not seem to made a diffrence
    any help would be great
    Anthony
    6000K HID kit FTW lights up the whole road and a few more in front ahahaha
    note also blinds people in front of you
    but hid is the best way to go...to get good light...mine ones are old as well but the hids just go right through it
    Senior Member Chairs with flares's Avatar
    Jeff
    East...
    Install a relay (one for low/high beams each) so your globes are getting the full 12-14v. Old wiring tends to get resistance with age, so your globes don't get the full voltage.
    If you are going to get a drop-in HID kit, make sure your housings are the type with a little cap over the front of the globe, otherwise you'll have massive amounts of glare to oncoming traffic and it'll be like you have your beams on to them, so they can't really judge your distance. Normal H4 globes have the front coated so light doesn't come out and it all hits the relflector, HID globes don't, which is why you need the housing with a cap, or projectors.
    J.
    Jonathan
    It has been said, just change to the late model AE86 complete headlights. They have better reflectors. I havn't tryed it myself yet.
    Site Supporter Javal's Avatar
    Josho
    Alighning them would be the first step.
    Then better globes
    Then re-running the wiring.
    Then switching to HID / switching to Kouki lights.
    Senior Member aaron's Avatar
    Aaron
    NOR
    I am thinking of just getting some xenon bulbs and whacking them in?
    In the range of about 4000-5000K so not too blue (keep the popo away). Just have to make sure they don't heat up too much.
    My old mans car did this and results were impressive aswell as being comparitively cheap to HID.
    gay
    n1gger land
    n1gger land
    south korea seoul
    are late model ae82 reflectors same as late model ae86 ones ??
    if so, could use the reflectors from kouki ae82 in adm ae86 lights.
    Gone
    Joel
    Picton
    i just wired in 2 relays and some heavy duty wiring and ran 110w/140 halogen globes.. plenty of light!!
    Jonathan
    Quote Originally Posted by sun_moon View Post
    The reflector is sort of part of the whole headlight body, and it does not bolt into AE86, so would not work.
    Jeff
    East...
    Those 4000+k halogen globes don't actually put out more light, they just appear to because of the color. The blue coating on the globe itself actually filters out some of the usable light so output is less.
    For standard H4 55/60w halogen globes, the best out there are the Philips Xtreme +80 or Osram Nightbreaker. I have the Philips ones and they are almost as bright as a generic 100w globe, without having to redo the wiring for added current draw. These globes don't really have the blue look if that's what you're after, but for the price, nothing really comes close for usable output.
    Check out some reviews online, that's pretty much what they all say.
    And make sure your lights are properly aimed too, if there is a pool of light right in front of the car, aim them up until you can light up a car in front's licence plate about 20-30m away on low beam. That way, the main beam will be where it should be.
    J.
  1. [WA] Toyota 4AGZE pistons $150 (Ideal for upgrading 4age to be turbo ready)
    By Ghetto-Spec .:bayka:. in forum Car Parts For Sale
    Last Post: 17th September 2012, 07:31 AM
  2. ae86 ecu upgrading
    By goose101 in forum Technical - Questions
    Last Post: 20th August 2012, 06:57 PM
  3. Wtb Ae86 white line tail lights, front kouki fog lights
    By timpy in forum Cars or Parts Wanted
    Last Post: 17th August 2011, 11:52 AM
  4. upgrading to a more modern car.
    By RolandGTV85 in forum General Topics (No Technical Questions)
    Last Post: 6th March 2009, 10:05 AM
  5. Upgrading fuel lines...
    By adsrx in forum Technical - Questions
    Last Post: 31st October 2005, 11:27 PM
