Results 1 to 8 of 8
Thread: WTB: Unmolested Struts/ 4AGE timing cover/ clock Surround
    Paul
    Default WTB: Unmolested Struts/ 4AGE timing cover/ clock Surround
    Guys,
    I am chasing a set of struts to replace the coil overs that are in mine, so I need the spring perches intact. They are a little over the top and not really required for what I am doing. I would prefer the XT130 type as that is that is in there now, but others will be considered just as long as they bolt up to the XT130 LCA and steering arms. I am in Canberra so that closer the better to save on cost. I don't need brakes, springs or shocks just the strut tube so I would think that $100 mark should get me there. If you have something that I might be interested in or know where I can some that would be great.
    I am also chasing the Upper Plastic Cam Belt cover for a 4AGE and the digital clock surround from the dash.
    Paul
    Andrew
    East Melbourne
    Hey Paul, I think I have a spare cam cover or two at my old's house in Canberra. I'll be there either this weekend or next, will let you know!
    If you find the struts you're after in Melbourne, I can take them to Canberra.
    Andrew
    Paul
    You sir are a scholar and a gentleman, I will let you know for sure.
    Paul
  • #4
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    I don't know how many times it has been said on these forums, but go to Toyota for a clock surround. They're only $15
  • #5
    Paul
    Thanks for the advise, I had priced other stuff at Toyota new and it was crazy expensive and made the incorrect assumption that this would be the same, now to really push my luck do you happen to have the part number at all
    Paul
  • #6
    Lawrence
    Wollongong
    55478-12040-01 - Black (You can't get any other color)
  • #7
    Senior Member Rip it's Avatar
    Jake
    Why is this in the car parts for sale section?? Mods??
    I got nothing.
  • #8
    Lawrence
    Wollongong
    Good question, moved.
  • Similar Threads
    1. WTB: Unmolested Dash cluster surround (ae86)
      By mc68 in forum Cars or Parts Wanted
      Last Post: 8th November 2011, 02:05 AM
    2. 20 valve timing cover spacer (middle timing cover, alloy plate)
      By KE70Man in forum Cars or Parts Wanted
      Last Post: 26th August 2011, 06:30 PM
    3. WTB: 20v cam cover and timing belt cover
      By grantobius in forum Cars or Parts Wanted
      Last Post: 25th May 2009, 08:23 AM
    4. WTB-4AGE cam covers/timing cover
      By Dori86 in forum Cars or Parts Wanted
      Last Post: 21st April 2007, 05:14 PM
