Hey Paul, I think I have a spare cam cover or two at my old's house in Canberra. I'll be there either this weekend or next, will let you know!
If you find the struts you're after in Melbourne, I can take them to Canberra.
Andrew
Guys,
I am chasing a set of struts to replace the coil overs that are in mine, so I need the spring perches intact. They are a little over the top and not really required for what I am doing. I would prefer the XT130 type as that is that is in there now, but others will be considered just as long as they bolt up to the XT130 LCA and steering arms. I am in Canberra so that closer the better to save on cost. I don't need brakes, springs or shocks just the strut tube so I would think that $100 mark should get me there. If you have something that I might be interested in or know where I can some that would be great.
I am also chasing the Upper Plastic Cam Belt cover for a 4AGE and the digital clock surround from the dash.
Paul
Andrew
You sir are a scholar and a gentleman, I will let you know for sure.
Paul
I don't know how many times it has been said on these forums, but go to Toyota for a clock surround. They're only $15
Thanks for the advise, I had priced other stuff at Toyota new and it was crazy expensive and made the incorrect assumption that this would be the same, now to really push my luck do you happen to have the part number at all
Paul
55478-12040-01 - Black (You can't get any other color)
Why is this in the car parts for sale section?? Mods??
I got nothing.
Good question, moved.
