struts, brake line, steering arms, that is all
i have a ke70 just wondering whats involed putting ae86 struts in?
are ae86 and ke/ae hubs the same?
no, i think hubs was assumed with complete ae86 struts
I have done this conversion. It all bolts in, but you will need:
complete ae86 struts/shocks/springs
ae86 calipers/discs/hubs (ae86 brakes are much bigger, which doesn't say much for ke70 gear)
ae86 brake lines (I changed to braided while I was at it, they screw straight into the ke70/ae71 hardlines)
ae86 or t18 steering arms (ke70 ones don't fit, I upgraded to ps arms at this point as well)
One thing to note is that if you use ae86 strut tops you will lose some caster - you can however use the ke70 tops with the ae86 spring hats to remedy this
It all 100% bolt in if you use these parts and you don't need to upgrade anything else to get the brakes working.
Any questions PM me
Driver of the yellow ae86
http://www.ae86drivingclub.com.au/fo...hlight=custard
what he said ^^ piss easy conversion
Thanks for the help guys
