Results 1 to 10 of 10
Thread: 4AC-4AGE Conversion
    Default 4AC-4AGE Conversion
    Did a quick search and nothing came up, I'm a total noob to this site.
    Car = ADM sprinter
    Engine = 16v 4age in FWD format c/w with loom & ECU
    I understand i'll need an intake.
    What do I keep from the 4AC?
    ie, stater motor, Alt, clutch and flywheel?
    Can I use the stock clutch fan for the rad?
    Will ADM T50 mate up?
    Will ADM gearbox input shaft work with FWD clutch and flywheel?
    Please if you know or have done this conversion answer my question.
    Al.
    Dave
    keep the 4ac untill the conversion is complete for when you need random bolts
    you need a 4age alternator, clutch and flywheel, none will fit from 4ac to 4age. any 4a starter will do the job, if your 4age came with one use that, if not use the 4ac one.
    not advisable unless you get a proper RWD water pump, as apparnetly the rwd water pumps will flog out due to the added pressure/vibrations of the fan. better to just get a thermo fan and wire it to the automatic temperature switch on the 4age.
    yes, you will need a spiggot bearing for your 4age crank (like $7)
    yes assuming they are 4age items, not 4ac
    and you are allowed to reply once you have read all of this
    http://www.billzilla.org/4agstock.htm
    Veteran slide86's Avatar
    Huw
    Hills
    Quote Originally Posted by FUTO_GT View Post
    Al.
    this entire site is all about this subject, im pretty surprised that the search returned nothing
    http://www.ae86drivingclub.com.au/fo...read.php?t=335
    For what I typed into search engine it turned up jack.
    Thanks for the link though.
    I must be really shit at the search engine.
    I can't find any articles on what to do to mod a FWD ae82 loom.
    Mostly I just find stuff for sale???
    gay
    n1gger land
    n1gger land
    south korea seoul
    4age is pretty dissapointing, just put a 253 v8 in.
    Dan
    Vic
    Western Subs
    i have one (253 v8) from my dads HJ monaro sitting in the garage... caby thou
    . h i t o r i k o .
    Veteran Nikkojoe's Avatar
    Tom
    ......I can't find any articles on what to do to mod a FWD ae82 loom.....
    What do you exactly want to mod? If you just want to get it working there isn't much to do. Read the link that slide86 gave, it includes my wiring guide for a bigport....
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    To do it properly its not a simple process. As such there aren't any guides.
    As Nikkojoe said, its possible to get it working without many mods to an AE82 loom. But it'll generally look pretty arse in your engine bay unless the entire loom is stripped apart and reworked.
    Quote Originally Posted by Golberg View Post
    I've done other conversions, did my mates 1UZ 2wd hilux, 808 1300 - injected 13B to name a few...
    I just wanted to ask those in the know what to look out for.
    I was checking out my loom today and I notice that the 14P plug is missing?
    I definitely need this plug yeah?
    What is it used for?
    Also mounted to the ECU cradle is an open circuit relay? i think
    This one
    What is this used for?
    There is no loom or plugs supplied to fit this...do I need it?
    Where is a good place to mount the ECU?
    Also, I was looking at the RWD 4AC water pump vs FWD 4age, and noted that the FWD has no thermostat supplied (AE82 has remote thermostat) however the RWD 4AC water pump rear housing has a thermostat. The only thing is that the outlet will not clear the ALT unless I either get a different outlet made up or I make a new longer top ALT braket...OR swap sides
    I tried the 4AC top ALT bracket, and it would nearly work, needs to be couple of cm's longer for adjusting belt tightness.
    Any help will be of much appreciation!
    Dave
    that thing on the back of your ecu is called your "circuit opening relay"
    its the relay to control your fuel pumps, so that when the engine stops running the fuel pumps will stop.
    grab an electrical diagram from somewhere, the wiring is fairly simple. and yes you need it.
    the14 pin plug is for all the powers, and yes you need it. its what most (if not all) the wires you need to connect to make the engine run.
    i belive you can get one from an oldish camry that will do the job, have a search around someone was talking about it somewhere not long ago (on this forum, or possibly rollaclub)
  1. Replies: 6
    Last Post: 15th November 2009, 11:38 PM
  2. 4ac - 4age 16v bigport conversion alternator question
    By Leigh in forum Technical - Questions
    Last Post: 19th May 2008, 03:04 PM
  3. 4ac to 16v 4age conversion
    By Gussy in forum Technical - Questions
    Last Post: 14th June 2006, 06:01 PM
