Results 1 to 10 of 13
Thread: T-18 drums
    Calvin
    Kilsyth
    Default T-18 drums
    hey guys,
    had a quick search but couldn't find what i'm after.
    i need new drums for my t18 and repco only had a listing for ra40 celica. just wondering if they'd be the same size etc?
    T18 in the build
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    both a T series diffs. they are both the same except for the extra track on the ra40 diff.
    they SHOULD work
    FTP.
    c
    i thought ra40 drums were bigger???
    Calvin
    Kilsyth
    i knew they were both t series but was unsure on the drums. i figure johnny rochester will know
    T18 in the build
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    RA60 have the same ones, EPC doesn't seem to think that RA40's do though.
    Site Supporter Javal's Avatar
    Josho
    Same as XT130 and RT132 Corona as well.
    Checked part numbers in RDA catalogue.
    Senior Member Stain's Avatar
    Derek
    Far North
    if ur gonna buy new drums why not just convert to disc?
    rt142 corona rear discs are almost a bolt on affair.
    Calvin
    Kilsyth
    well its only a daily drifter so don't need any huge stopping power. drums are cheap and lock the handbrake up well and the brake conversion might need engineering. thanks for the advice guys. will order them next week
    T18 in the build
    Derek
    Far North
    rt142 have an internal drum inside the rotor, so you have a drum handbrake and caliper footbrake. best of both words.
    since the rt142 is a t-series rear end and its pretty much bolt on its dead easy to get a mod plate for.
    Quote Originally Posted by Stain View Post
    Problem is, he would then have to get everything else engineered, and thats probably not going to happen.
  1. wtb drums off a s or t diff
    By dehney in forum Adelaide & SA Events and Discussion
    Last Post: 13th July 2009, 01:27 PM
  2. drums are stuck
    By shinny in forum Technical - Questions
    Last Post: 5th February 2009, 08:04 PM
  3. S and T series drums
    By Mr Fujiwara in forum Technical - Questions
    Last Post: 27th July 2008, 12:05 PM
  4. drums/ interior wanted
    By sik-86 in forum Cars or Parts Wanted
    Last Post: 20th February 2007, 04:44 PM
  5. ae86 rear drums
    By sik-86 in forum Technical - Questions
    Last Post: 13th February 2007, 07:18 PM
