Results 1 to 10 of 11
Thread: Do I need to use my brake balance adjuster valve thingy yet?
    Senior Member Beck's Avatar
    Andrew
    Default Do I need to use my brake balance adjuster valve thingy yet?
    The situation:
    JDM diff/rear end, rest of the brake system is ADM. I have a JDM brake proportioning valve sitting here in anticipation of putting something a bit beefier on the fronts. I've noticed that the rear wheels get dirty from brake pad dust quite a bit quicker than the fronts, which is my (probably dumb) reasoning for asking these questions:
    Is there an easy way (apart from locking up the brakes at speed) to tell if my F/R bias is "correct"?
    What IS the correct balance F/R? (60f/40r?)
    Pretty much trying to work out if I should install this JDM valve now, or wait until I upgrade the front, which could be a few months off.
    Thanks,
    -B.
    Because race car.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    The proportioning valve is different because the JDM rears usually run discs, assuming you have a disc rear end then DEFINITELY put the proportioning valve in. If you are still running the ADM prop valve its no wonder you're munching rear pads.
    The ADM front's are exactly the same as the JDM's anyway, the only difference is they are wider to allow for the wider vented rotors. They require the same amount of fluid, pressure & bias as the JDM ones.
    dan
    adelaide
    adelaide
    i thought good balance was around 70f/30r
    Jonathan
    What does this mean and how did you even work it out? You must have put fluid pressure gauges on your car or something.
    dan
    adelaide
    adelaide
    i wouk with a brake company and we checked it wanted to get it right
    Andrew
    Okay cool. Thanks for that, will put the valve in asap.
    Because race car.
    Elite rthy's Avatar
    Leo
    Tulla
    i had the same problem, pv is required
    andrew
    under your master cylinder you will have a 4 line splitter proportioning valve just take that off and pull it apart (take the sping and valve out of it) put it back and it should work.
    Member jy086's Avatar
    Nunawading
    so if i have the JDM disk rear end and still using the ADM master cylinder and also have upgrade front brakes. do i still need the proportioning valve? if so where can i get one? thanks
    Lawrence
    Wollongong
    The drums need more fluid than rear discs, so whatever you do, if you've got a disc rear end you need to atleast modify the prop valve if nothing else.
  1. Brake MC - One way valve?
    By Victim in forum Technical - Questions
    Last Post: 3rd March 2010, 09:54 PM
  2. Brake Bias Adjuster
    By stouty in forum Technical - Questions
    Last Post: 23rd February 2010, 10:28 AM
  3. BRake Lines - Brake Booster One-Way valve
    By bigm in forum Cars or Parts Wanted
    Last Post: 29th January 2010, 06:56 AM
  4. Brake balance
    By damo46 in forum Technical - Questions
    Last Post: 24th July 2008, 05:31 PM
  5. jdm brake proportion valve
    By quoccy in forum Cars or Parts Wanted
    Last Post: 22nd October 2007, 06:43 PM
