Results 1 to 10 of 12
Thread: Converting to W5X gearbox with an adaptor plate
    Veteran biggo's Avatar
    Nick
    Noosa
    What i used:
    AZCustoms bellhowing adator plate to mate T50 and W5X
    W57 out of an RA60 Celica
    4a spigot bearing (PN 6001)
    200mm Flywheel
    HD Pressure plate
    New Clutch plate (more on this below)
    86 tailshaft with RA65 front half
    Standard T50 clutch fork, slave cyl and master
    Cutosm Throwout/thrust bearing carrier
    Now where to start....
    Here is a W57 (and my dodgy mount)
    T50
    Adaptor plate kit (comes with spigot holder and bolts)
    What you need to do:
    Bolt up the adaptor kit
    Make your own xmemeber (86 and ke70s are different, ketos are 'wider')
    Sort out your clutch, I used an old landcruiser Clutch plate. It was 200mm x29 splines BUT it was .5mm to small. As in i didnt slide over the input. Probably an old P series gbox plate. Id seriously recommend just getting the center swaped on you 4a clutch plate.
    Get a throwout bearing carrier, Ive heard numerous reports of what works From MZxx something to hiluxes. As you can buy these new itd be a goer except they do not have a part number book at my auto shop it would have been a hit or miss. I just made my own up using the T50 throw out as a guide of the hight. I also added 20mm to the back to be safe that it didnt fall off the input shaft cover.
    When selecting a W5x gbox, you must get a center mounted shift (like mine) if you don't want to cut up the shifter hole. Ive heard reports of complete bellhousings that fit onto W5X's change the shifter to the passenger side. Heres a pic of dr1ft-pig's setup using a dellows bellhousing.
    I did this conversion complete with new clutch for $600 and apexi RSM. So if you got the hookups and welding skills id say got for it!
    Senior Member gaz20v's Avatar
    Gareth
    Lismore
    how much are those adapter plates?? and where abouts do they come from?
    Senior Member 350hp4agte's Avatar
    underwood
    qld
    jimboomba
    <div class='quotetop'>QUOTE (gaz20v @ Mar 14 2008, 07:07 PM) </div>+1
    Nick
    Noosa
    err you guys must be new. They come from AZcustoms
    PM klusio on here. Or look up the TAS section here.
    Last report was around $300 New
    Aaron
    Vic
    Ballarat
    Can you use the comercial gearboxes with the longer input shafts with this adator plate?
    Nick
    Noosa
    i dunno, i was under the opinion that ALL W50/55/56/57/58's were the same aside from the shifter housing/transfer case.
    How ever i fail to see how a longer input shaft will work, the adaptor is designed to bring the box upto the same length as the t50.
    Which commercial box are you talking about exactly?
    Elite rthy's Avatar
    Leo
    Tulla
    W50 is apparently different but yeah otherwise they are all meant to be the same
    Aaron
    Vic
    Ballarat
    I was thinking of the R154 or the G boxes from diesel 2wd hilux, that have the 190mm input shaft as opposed to the 160mm. Maybe with a longer input shaft you would not need to space the spigot bearing.
    Veteran slide86's Avatar
    Huw
    Hills
    works ok with a JDM t50 bellhousing?
    they should be the same so it sholdnt matter.....
    Nick
    Noosa
    i don't see it being an issue slide86
    a t50 bellhousing is a t50 bellhousing
    reguardless of which side the slave is on
  1. w5x to 4a adaptor plate
    By _wanna-be_ in forum Technical - Questions
    Last Post: 17th July 2012, 05:51 AM
  2. WTB adaptor plate W5X TO T50 or hole conversion
    By _wanna-be_ in forum Cars or Parts Wanted
    Last Post: 5th July 2012, 08:31 PM
  3. Replies: 3
    Last Post: 19th May 2012, 03:34 PM
  4. Replies: 13
    Last Post: 18th July 2007, 11:37 PM
