Results 1 to 7 of 7
Thread: removing center tailshaft bearing
    Senior Member Stej's Avatar
    Steve
    Default removing center tailshaft bearing
    Hey, iam a unsure on how to remove the center tailshaft bearing?
    cheers,
    Steve
    Veteran Konakid's Avatar
    Henry
    Eastern
    Take it to a tail shaft joint and they will do it for you.
    Veteran driftism's Avatar
    Andrew
    Watsoia
    Why do you want to remove it? just get a new tail shaft if its fucked.
  • #4
    Site Supporter Javal's Avatar
    Josho
    Quote Originally Posted by driftism View Post
    Just putting in another tailshaft means you're putting in another 2nd hand center bearing.
    Replacing them is a surprisingly smart option to ensure longevity.
    As said before, take it to a tailshaft / driveshaft place. The Toyota ones are bastards to replace if memory serves.
  • #5
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    flat nose screwdriver and a mallet is how i removed mine it takes a long time
  • #6
    Paul
    Should cost around $150 to get it replaced if thats the option you choose.
  • #7
    Steve
    yer i want to replace it as new and dont really want to use a second hand one.
    Repco, Auto1, or any other good auto parts store should stock or beable to order a new bearing in?
  • Similar Threads
    1. Pulling down a 7afe engine - Removing crank bearing caps
      By Matt in forum Technical - Questions
      Last Post: 15th May 2012, 07:14 PM
    2. T18 center bearing
      By tea18 in forum Technical - Questions
      Last Post: 4th January 2011, 07:20 PM
    3. WTD: Ae71/Ke70 centre bearing or tailshaft
      By hugh in forum Cars or Parts Wanted
      Last Post: 6th December 2009, 01:21 PM
    4. Removing gearbox/tailshaft from an 86
      By luke86 in forum Technical - Questions
      Last Post: 28th March 2009, 07:52 AM
    5. Tail shaft center bearing
      By daz in forum General Topics (No Technical Questions)
      Last Post: 26th October 2007, 11:25 AM
