get yourself an "easy out"
you will need to get your drill in there to use this method
the "easy out" will contain 1 small drillbit and 1 left hand threaded screw that goes in your drill
the rest explains itself, drill the hole, use the left hand thread to undo the bolt
if you do this DO IT SLOWLY AND CAREFULLY OR YOU WILL BREAK THE EASY OUT!!!
hope i helped
